Forum: ARM programming with GCC/GNU tools help:Why YAGARTO can't accept the option"-mcpu=cortex-m4" ?
von cortex m. (Company: cumtb) (cortex-m4)
The newest YAGARTO GNU ARM toolchain is with GCC-4.6,and the GCC-4.6
should support cortex-m4 using the option "-mcpu=cortex-m4"(refer to
http://gcc.gnu.org/gcc-4.6/changes.html).
But when I using the option "-mcpu=cortex-m4",it show
Error: unknown cpu `cortex-m4'
Error: unrecognized option -mcpu=cortex-m4
So why it can not support the option?
von Michael F. (mifi)
Hello ???
This is correct, this version of YAGARTO is not build for Cortex-M4.
Regards,
mifi
Hello,
perhaps the next version will support M4.
Regards,
mifi
Michael Fischer wrote:
> Hello,
> Regards,
> mifi
Thanks for reply,It can support the cortex-m4 in the newest version.
But I can't use  floating point arithmetic in my C program.
main.o: In function `main':
D:\cygwin\home\houxn\main\m3/main.c:6: undefined reference to
`__aeabi_fmul'
`__aeabi_fmul'
I think it may lack soft-float library,but I don't know how to solve it.
Moreover,I want to use FPU in cortex-m4,it can not generate FPU code
like "VMUL.F32      s3,s1,s0"
Hello,
Soft floating point is working, take a look in the K40
example here:
http://www.yagarto.de/download/yagarto/K40Test.zip
Use the option "-mfloat-abi=hard". I think this should produce
code for a FPU unit.
Btw, which CPU you are using?
Regards,
mifi
> Hello,
> example here:
Thanks a lot! I just make it successfully by using the option
"-mfloat-abi=hard".
My CPU is K60,a product of Freescale.32-bit ARM Cortex-M4 core with DSP
support MPU.
I thought that the free GNU tools would not support so new CPU but only
Keil etc..But I was wrong.
Another question is that if I use cortex-m3 (without DSP unit),how can I
do if I want it generates soft-float code ?
I just use "-mfloat-abi=soft",but it was wrong:
undefined reference to `__aeabi_fmul'
How can I do ?
Where can I find the support information such as use "-mfloat-abi=hard"
or what files should I refer to ?
Thanks!
von Jörg W. (dl8dtl) (Moderator)
$ arm-none-eabi-gcc --target-help
The following options are target specific:
  -mabi=                      Specify an ABI
  -mabort-on-noreturn         Generate a call to abort if a noreturn function
                              returns
  -mandroid                   Generate code for the Android operating system.
  -mapcs-float                Pass FP arguments in FP registers
  -mapcs-frame                Generate APCS conformant stack frames
  -mapcs-reentrant            Generate re-entrant, PIC code
  -march=                     Specify the name of the target architecture
  -mbig-endian                Assume target CPU is configured as big endian
  -mcallee-super-interworking Thumb: Assume non-static functions may be called
                              from ARM code
  -mcaller-super-interworking Thumb: Assume function pointers may go to non-
                              Thumb aware code
  -mcirrus-fix-invalid-insns  Cirrus: Place NOPs to avoid invalid instruction
                              combinations
  -mcpu=                      Specify the name of the target CPU
  -mfix-cortex-m3-ldrd        Avoid overlapping destination and address
                              registers on LDRD instructions that may trigger
                              Cortex-M3 errata.
  -mfloat-abi=                Specify if floating point hardware should be used
  -mfp16-format=              Specify the __fp16 floating-point format
  -mfpu=                      Specify the name of the target floating point
                              hardware/format
  -mhard-float                Alias for -mfloat-abi=hard
  -mlittle-endian             Assume target CPU is configured as little endian
  -mlong-calls                Generate call insns as indirect calls, if
                              necessary
30
  -mpic-register=             Specify the register to be used for PIC addressing
31
  -mpoke-function-name        Store function names in object code
32
  -msched-prolog              Permit scheduling of a function's prologue
33
                              sequence
34
  -msingle-pic-base           Do not load the PIC register in function prologues
35
  -msoft-float                Alias for -mfloat-abi=soft
36
  -mstructure-size-boundary=  Specify the minimum bit alignment of structures
37
  -mthumb                     Compile for the Thumb not the ARM
38
  -mthumb-interwork           Support calls between Thumb and ARM instruction
39
                              sets
40
  -mtp=                       Specify how to access the thread pointer
41
  -mtpcs-frame                Thumb: Generate (non-leaf) stack frames even if
42
                              not needed
43
  -mtpcs-leaf-frame           Thumb: Generate (leaf) stack frames even if not
44
                              needed
45
  -mtune=                     Tune code for the given processor
46
  -mvectorize-with-neon-quad  Use Neon quad-word (rather than double-word)
47
                              registers for vectorization
48
  -mword-relocations          Only generate absolute relocations on word sized
49
                              values.
50
  -mwords-little-endian       Assume big endian bytes, little endian words
51
52
  Known ARM CPUs (for use with the -mcpu= and -mtune= options):
53
    cortex-m0, cortex-m1, cortex-m3, cortex-r4f, cortex-r4, cortex-a9,
54
    cortex-a8, cortex-a5, arm1156t2f-s, arm1156t2-s, mpcore, mpcorenovfp,
55
    arm1176jzf-s, arm1176jz-s, arm1136jf-s, arm1136j-s, arm1026ej-s, arm926ej-s,
56
    iwmmxt2, iwmmxt, xscale, arm1022e, arm1020e, arm10e, arm968e-s, arm966e-s,
57
    arm946e-s, arm9e, arm1020t, arm10tdmi, ep9312, arm940t, arm922t, arm920t,
58
    arm920, arm9tdmi, arm9, arm740t, arm720t, arm710t, arm7tdmi-s, arm7tdmi,
59
    strongarm1110, strongarm1100, strongarm110, strongarm, arm810, arm8,
60
    arm7dmi, arm7dm, arm7m, arm7500fe, arm7500, arm7100, arm710c, arm720,
61
    arm710, arm700i, arm700, arm70, arm7di, arm7d, arm7, arm620, arm610, arm600,
62
    arm60, arm6, arm3, arm250, arm2
63
64
  Known ARM architectures (for use with the -march= option):
65
    iwmmxt2, iwmmxt, ep9312, armv7e-m, armv7-m, armv7-r, armv7-a, armv7,
66
    armv6-m, armv6t2, armv6zk, armv6z, armv6k, armv6j, armv6, armv5te, armv5e,
67
    armv5t, armv5, armv4t, armv4, armv3m, armv3, armv2a, armv2
68
 ARM-specific assembler options:
69
  -k                      generate PIC code
70
  -mthumb                 assemble Thumb code
71
  -mthumb-interwork       support ARM/Thumb interworking
72
  -mapcs-32               code uses 32-bit program counter
73
  -mapcs-26               code uses 26-bit program counter
74
  -mapcs-float            floating point args are in fp regs
75
  -mapcs-reentrant        re-entrant code
76
  -matpcs                 code is ATPCS conformant
77
  -mbig-endian            assemble for big-endian
78
  -mlittle-endian         assemble for little-endian
79
  -mapcs-frame            use frame pointer
80
  -mapcs-stack-check      use stack size checking
81
  -mno-warn-deprecated    do not warn on use of deprecated feature
82
  -mcpu=<cpu name>        assemble for CPU <cpu name>
83
  -march=<arch name>      assemble for architecture <arch name>
84
  -mfpu=<fpu name>        assemble for FPU architecture <fpu name>
85
  -mfloat-abi=<abi>       assemble for floating point ABI <abi>
86
  -meabi=<ver>            assemble for eabi version <ver>
87
  -mimplicit-it=<mode>    controls implicit insertion of IT instructions
88
  -EB                     assemble code for a big-endian cpu
89
  -EL                     assemble code for a little-endian cpu
90
  --fix-v4bx              Allow BX in ARMv4 code
91
92
Linker options
93
94
95
Use "-Wl,OPTION" to pass "OPTION" to the linker.
96
97
armelf:
98
  --build-id[=STYLE]          Generate build ID note
99
  -Bgroup                     Selects group name lookup rules for DSO
100
  --disable-new-dtags         Disable new dynamic tags
101
  --enable-new-dtags          Enable new dynamic tags
102
  --eh-frame-hdr              Create .eh_frame_hdr section
103
  --hash-style=STYLE          Set hash style to sysv, gnu or both
104
  -z combreloc                Merge dynamic relocs into one section and sort
105
  -z defs                     Report unresolved symbols in object files.
106
  -z execstack                Mark executable as requiring executable stack
107
  -z initfirst                Mark DSO to be initialized first at runtime
108
  -z interpose                Mark object to interpose all DSOs but executable
109
  -z lazy                     Mark object lazy runtime binding (default)
110
  -z loadfltr                 Mark object requiring immediate process
111
  -z muldefs                  Allow multiple definitions
112
  -z nocombreloc              Don't merge dynamic relocs into one section
113
  -z nocopyreloc              Don't create copy relocs
114
  -z nodefaultlib             Mark object not to use default search paths
115
  -z nodelete                 Mark DSO non-deletable at runtime
116
  -z nodlopen                 Mark DSO not available to dlopen
117
  -z nodump                   Mark DSO not available to dldump
118
  -z noexecstack              Mark executable as not requiring executable stack
119
  -z now                      Mark object non-lazy runtime binding
120
  -z origin                   Mark object requiring immediate $ORIGIN
121
                                processing at runtime
122
  -z max-page-size=SIZE       Set maximum page size to SIZE
123
  -z common-page-size=SIZE    Set common page size to SIZE
124
  -z KEYWORD                  Ignored for Solaris compatibility
125
  --thumb-entry=<sym>         Set the entry point to be Thumb symbol <sym>
126
  --be8                       Output BE8 format image
127
  --target1=rel               Interpret R_ARM_TARGET1 as R_ARM_REL32
128
  --target1=abs               Interpret R_ARM_TARGET1 as R_ARM_ABS32
129
  --target2=<type>            Specify definition of R_ARM_TARGET2
130
  --fix-v4bx                  Rewrite BX rn as MOV pc, rn for ARMv4
131
  --fix-v4bx-interworking     Rewrite BX rn branch to ARMv4 interworking veneer
132
  --use-blx                   Enable use of BLX instructions
133
  --vfp11-denorm-fix          Specify how to fix VFP11 denorm erratum
134
  --no-enum-size-warning      Don't warn about objects with incompatible
135
                                enum sizes
136
  --no-wchar-size-warning     Don't warn about objects with incompatible
137
                                wchar_t sizes
138
  --pic-veneer                Always generate PIC interworking veneers
139
   --stub-group-size=N   Maximum size of a group of input sections that can be
140
                           handled by one stub section.  A negative value
141
                           locates all stubs after their branches (with a
142
                           group size of -N), while a positive value allows
143
                           two groups of input sections, one before, and one
144
                           after each stub section.  Values of +/-1 indicate
145
                           the linker should choose suitable defaults.
146
  --[no-]fix-cortex-a8        Disable/enable Cortex-A8 Thumb-2 branch erratum fix
>How can I do ?
Take a look here at my examples page:
http://www.yagarto.de/examples/index.html
Take one example, DO NOT change the makefile, and
add a multiplication. It will work, have make a
fast test with the LPC1343.
Thanks,I have solved my problem.
When linking,I used "arm-none-eabi-ld" but the example above use
"arm-none-eabi-gcc",and the latter is work.
I have built my own toolchain in fedora refer to your
build-scripts-20110429.
Before that I have built "arm-elf-*" toolchain,but it have some
problems(and I can't explain why).
Now the "arm-none-eabi-*" toolchain works well,and I find it appears
more efficient than windows version.But the windows version is more
convenience,because I have to run VMware if I want to use linux version.
von Ilija K. (ilija_k)
>> Hello,
>> example here:
> "-mfloat-abi=hard".
> support MPU.
Hi
Has your K60 an FPU? I have got TWR-K60N512-KIT but it has no FPU.
Ilija
Hello Ilija,
I have only a K40 but if you compare the both picture from:
K40:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=K40
K60:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=K60
It looks that the K60 had a floating point unit.
Best regards,
Michael
Hi Michael
> Hello Ilija,
> K40:
> K60:
FPU is an option for K60, but I don't know if there are ones with FPU
available yet. Mine is without.
I have built (just-enough) GCC 4.6.0 only to discover that FPU is
missing.
Regards
Ilija
Hello Ilija,
what is the full product number of your device?
Compared to the "Product Brief" of the K60 you will
find the information in section "4.3 Part Numbers and
Packaging". Here specially the "Key attribute".
Do you have a K60D or K60F?
Regards,
Michael
> Hello Ilija,
D and F are new markings introduced a week ago. Old markings (check
older Product brief release if you have on) do not contain D/F
designation.
FYI present TWR modules have chip with designation K60N512VMD100
Ilija
