Forum: ARM programming with GCC/GNU tools STM32 GDB / OpenOCD Commands and Initialization for Flash and Ram Debugging
Author: Jim T. (jim_t)
I am looking for assistance with the proper GDB / OpenOCD initializion
and run commands to use within Eclipse for flash and ram debugging.
Also, the proper modifications or additions that need to be incorporated
in a make file for flash vs ram building for this mcu, if this matters
of course.
mcu: STM32F103VET6
I am using Eclipse Helios with Zylin Embedded CDT, Yagarto Tools and
Bins, OpenOCD .4, and have an Olimex ARM-USB-OCD-H Jtag adapter.
I have already configured the ARM-USB-OCD and added it as an external
tool in  Eclipse. For initializing OpenOCD I used the  following command
in Eclipse (The board config file references the stm32 mcu and was found
in the OpenOCD installation as an example):
"openocd -f interface/olimex-arm-usb-ocd-h.cfg -f
board/stm32f10x_128k_eval.cfg".
When I run this within Eclipse everything appears to be working (GDB
Interface, OpenOCD finds the mcu, etc) .I can also telnet into OpenOCD
and run commands.
So, I am stuck on the next part; initialization and commands for flash
and ram debugging , as well as erasing flash.
I read through several tutorials, and scoured the net, but have not been
able to find anything particular to this processor. I am new to this, so
I might not be recognizing an equivent product for/as a suitable
example.
Any help would be greatly appreciated.
Jim T
Author: tom (Guest)
jim,
take a look at the STM32F... example at the yagarto site how to setup a
makefile for RAM and FLASH target.
try to understand the example (memory maps) before u proceed.
look at the jlink command scripts and look into the segger jlink gdb
server manual, where u can find hints about debugging cortex-m3.
start with deriving an openocd config for debugging in RAM. if this
works take next step with programming the flash via openocd. if this
works setup a programming+debug sequence.
good luck.
