Forum: ARM programming with GCC/GNU tools The gap between RO and RW segments
Author: liang ma (Company: TK) (etarip)
I'm doing something in memory lacking situations. When a shared object
is loaded, there will be a memory gap between RO and RW segments.
Running fromelf on a so file, I could get these:
** Program header #1
    Type          : PT_LOAD (1)
    File Offset   : 0 (0x0)
    Virtual Addr  : 0x00000000
    Physical Addr : 0x00000000
    Size in file  : 20468 bytes (0x4ff4)
    Size in memory: 20468 bytes (0x4ff4)
    Flags         : PF_X + PF_R (0x5)
    Alignment     : 32768
** Program header #2
    Type          : PT_LOAD (1)
    File Offset   : 20468 (0x4ff4)
    Virtual Addr  : 0x0000cff4
    Physical Addr : 0x0000cff4
    Size in file  : 264 bytes (0x108)
    Size in memory: 40608 bytes (0x9ea0)
    Flags         : PF_W + PF_R (0x6)
    Alignment     : 32768
The gap is 32K (from 0x4ff4 to 0x0000cff4).
I've tried RVCT armlink and yagarto arm-none-eabi-ld, they are both 32K.
And using Sourcery G++ arm-uclinuxeabi-ld, it's just a little bigger.
When I tried arm-eabi-ld from Android ndk r5, it's only 4K. So I finally
choose Android ndk r5 arm-eabi-ld as my linker to save memory.
But I couldn't figure out why there will be such a big gap. Are there
any options to control its size?
Please help me out, thank you very much.
