Forum: FPGA, VHDL & Verilog what is wrong with my code?
Author: aji sydin (aji)
I AM A NEWBIE IN VERILOG AND JUST DONT KNOW WHAT IS WRONG WITH MY CODE.
THIS IS THE CRAZY SIMPLE QUESTION :
Develop a Verilog model for a thermostat that has two 8-bit unsigned
binary inputs representing the target temperature and the actual
temperature in degrees Fahrenheit (˚F). Assume that both temperatures
are above freezing (32˚F). The detector has two outputs: one to turn a
heater on when the actual temperature is more than 5˚F below target, and
one to turn a cooler onwhen the actual temperature is more than 5˚F
above target.
AND THIS IS MY CODE:
module*C2*(switch,clk,heater_on,cooler_on,enable_a ctual,enable_target);
input clk;
input enable_actual,enable_target;
input*[7:0]*switch*;
reg [7:0]*actual,target;
output* heater_on,*cooler_on;
always @(posedge clk)
begin
if (enable_actual) actual <= switch;
else if (enable_target) target <= switch;
end
assign*heater_on*=*actual*<*target*-*5;
assign*cooler_on*=*actual*>*target*+*5;
endmodule
IT DIDN'T SHOW ANY ERROR DURING COMPILATION.THE PROBLEM IS THAT THE
OUTPUT WHICH HEATER_ON AND COOLER_ON DIDN'T ON CORRECTLY.WHAT IS WRONG
WITH MY CODE??CAN SOMEBODY PLS HELP ME.
PICTURE2 IS THE SIMULATION WHEN I WANT THE HEATER_ON ONLY TO BE ON
PICTURE4 IS THE SIMULATION WHEN I WANT THE COOLER_ON ONLY TO BE ON
BUT THE SIMULATION WAS NOT WHAT I EXPECTED FOR:HELP PLS
Author: bla (Guest)
I took the liberty to format your code a little:
module C2 (switch, clk, heater_on, cooler_on, enable_actual, enable_target);
    input  clk;
    input  enable_target;
    input  [7:0] switch;
    reg    [7:0] actual;
    reg    [7:0] target;
    output heater_on;
    output cooler_on;
    begin
        if (enable_actual)
            actual <= switch;
        else
            if (enable_target)
                target <= switch;
    end
    assign heater_on = actual < (target-5);
    assign cooler_on = actual > (target+5);
endmodule
please add the signals "actual" and "target" to your simulation.
it also would be nice to see the 8 bit registers as decimals instead of
characters.
as long as "actual" and "target" are not set to something else than "0",
don't wonder "heater_on = actual < (target-5);" is true, as (0-5) =
(256-5) = 251
so I would set target first.
  • [vhdl]VHDL code[/vhdl]
