Forum: ARM programming with GCC/GNU tools Problem disabling cache on ARM926ej-s
von A. S. (aleksazr)
I've been using mmu.c to setup my MMU table
and enable the caches - for months now,
so I think that part is OK.
Now I need to disable the icache, dcache and mmu,
do some stuff and re-enable them.
But when I disable the cache, the prog starts to
behave like it has a will of its own.
If I don't disable the cache, then it works normally.
Please take a look...
// creates a mmu level 1 table with flat address space.
#define not_cacheable (1 << 1) // C=B=0 (bit 1 must be set = section
descriptor)
#define     cacheable (7 << 1) // C=B=1 (bit 1 must be set = section
descriptor)
#define SDRAMsize (32*M)
#define SDRAMstart  (AT91C_EBI_SDRAM >> 20)
#define SDRAMend   ((AT91C_EBI_SDRAM + SDRAMsize) >> 20)
static void mmu (void) {
    uint f;
    uint *pSDRAM = (uint*) AT91C_EBI_SDRAM;
    // create table
        // setup all linear addresses, AP(3), domain(0), bit 4(1)
        // as non-cacheable and as invalid entry
        for (f = 0; f <= 4095; f++)
            pSDRAM[f] = (f << 20) | (3 << 10) | (1 << 4);
        // 1st MB is not user accesible
        pSDRAM[0] &= (DWORD) ~(1 << 11);
        // 1st 6MB are not cacheable
        for (f = 0; f <= 5; f++)
            pSDRAM[f] |= not_cacheable;
        // peripherals are not cacheable
        pSDRAM[4095] |= not_cacheable;
        // EBI 6 not cacheable
        pSDRAM[AT91C_EBI_CS6 >> 20] |= not_cacheable;
        // whole SDRAM is cacheable
        for (f = SDRAMstart; f < SDRAMend; f++)
            pSDRAM[f] |= cacheable;
    // TTBR
        asm("LDR R0, =0x20000000");
        asm("MCR P15, 0, R0, C2, C0, 0");
    //assert DACR.D0 (client mode)
        asm("MRC P15, 0, R0, C3, C0, 0");
        asm("BIC R0, R0, #3");
        asm("ORR R0, R0, #1");
        asm("MCR P15, 0, R0, C3, C0, 0");
    // Enable Icache(12), Dcache(2), Alignment(1) and MMU(0)
        asm("MRC P15, 0, R0, C1, C0, 0");
        asm("ORR R0, R0, #4096");
        asm("ORR R0, R0, #7");
        asm("MCR P15, 0, R0, C1, C0, 0");
This is in sram0, called from user mode with SVC instruction.
disablecache:   mov r0,#0                       @ drain write buffer
                mcr p15, 0, r0, c7, c10, 4
                mcr p15, 0, r0, c7, c6, 0       @ invalidate dcache
                mrc p15, 0, r0, c1, c0, 0       @ Disable Icache(12),
Dcache(2) and MMU(0)
                bic r0, r0, #4096
                bic r0, r0, #5
                mcr p15, 0, r0, c1, c0, 0
                mov pc,lr                       @ return to SWI handler
When I'm done, I re-enable the cache (but the prog never reaches here)
enablecache:    mrc p15, 0, r0, c1, c0, 0       @ Enable  Icache(12),
                orr r0, r0, #4096
                orr r0, r0, #7
                mov pc,lr
I've copied (almost) this from linux, and it still doesn't work.
disablecache:   mrc p15, 0, r15, c7, c14, 3     @ test, clean and
invalidate
                bne DisableCache
                mov r0,#0
                mcr p15, 0, r0, c7, c5, 0       @ invalidate I cache
                mcr p15, 0, r0, c7, c10, 4      @ drain write buffer
                bic r0, r0, #4096
                bic r0, r0, #5
                mov pc,lr
Can anyone see a problem here?
Got it!
"bne DisableCache" should be "bne disablecache"
