Forum: ARM programming with GCC/GNU tools need help porting function to C
von Mario K. (lastyle)
Hello Guys,
i need help porting a function to c for my Mega32. Could anybody please
help me with the following ?I tried several Times but failed all the
time :-(
pullup =  220                            'not as static value, might
change
adc = 500                                'will be read from mega later
B = 3963                                 'Bwert NTC
Ts = 333.15                              'Bezugstemperatur in Kelvin
60°C
rs = 221                                 'Widerstand bei
Bezugstemperatur TS
temp = ((b * Ts) / ((Ts * (Log(((((0.0047898 * adc) * pullup) / (4.9 -
(0.0047898 * adc))) / rs)))) + b)) - 273.15
Thanks in Advance
von Helper (Guest)
#include <avr/io.h>
#include <math.h>
// Testdata
uint16_t pullup = 220; // not as static value, might change
uint16_t adc = 500;    // will be read from mega later
int16_t B = 3963;      // Bwert NTC
double Ts = 333.15;    // Bezugstemperatur in Kelvin 60°C
uint16_t rs = 221;     // Widerstand bei Bezugstemperatur TS
double temp = 0;
int main(void)
  temp = ((B * Ts) / ((Ts * (log(((((0.0047898 * adc) * pullup)
         / (4.9 - (0.0047898 * adc))) / rs)))) + B)) - 273.15;
  asm volatile ("nop");
1) Ergebnis: temp = 61.4
2) log = natürlicher Logarithmus
http://www.nongnu.org/avr-libc/user-manual/group__avr__math.html#ga7f7d556ab6b6235777a179647c152126
3) Projektoptionen in AVR-Studio:
libm.a hinzufügen
I worked on the function a bit but it didnt work yet, what i did
uint32_t temp;
// b = 3963                                 'Bwert vom NTC
// Ts = 333.15                              'Bezugstemperatur in Kelvin
hier 60°C
// rs = 221                                 'Widerstand bei
Bezugstemperatur TS
analog = adcwert(i);
temp =((3963 * 333.15) / ((333.15 * (log(((((0.0047898 * analog) * 1242)
/ (4.9 - (0.0047898 * analog))) / 221)))) + 3963)) - 273.15;
sendUSART(temp);
but i get the wrong data, mhh
von Helper (Guest)
Shit happens.
Danke,wunderbar das deckt sich fein mit meinen 61,39
libm.a hab ich drin, aner wenn ich das nun über usart schicken möchte
meckert der compiler rum
sendUSART(temp);
../measure.c:158: error: incompatible type for argument 1 of 'sendUSART'
muss ich das vorher noch wandeln ?
von Helper (Guest)
Yes.
The dtostrf() function converts the double value passed in val into an
ASCII representationthat will be stored under s. The caller is
responsible for providing sufficient storage in s.
http://www.nongnu.org/avr-libc/user-manual/group__avr__stdlib.html#ga060c998e77fb5fc0d3168b3ce8771d42
Works like a Charm now, just one Problem i still have is that i need the
resulting value temp converted to single hex values.
Meaning if a Temperature result would be 12.9 i want to have a result of
seg0 = 1
seg1 = 2
seg2 = 9
i tried with
  dtostrf(temp,3,1,ascii);sendUSART(ascii); sendUSART("\r\n");
  if ( temp > 10 )
        strncpy(seg0, ascii , 1);
  strncpy(seg1, ascii +1, 1);
  strncpy(seg2, ascii +3, 1);
but since this still results the ascii values
(seg0 ="1",seg1 ="2" and seg2 ="9")
, how do i convert them to hex codes ?
Thanks in Advance
von Helper (Guest)
'0' = 0 + '0'
'1' = 1 + '0'
go figure
Tried that before already, but i stll need to convert the Value since
the Compiler gives me
error: lvalue required as increment operand
Since i needed to define my seg0 to seg9 values as char i cant add '0'
von Helper (Guest)
I don't get it.
