Forum: ARM programming with GCC/GNU tools Lookup Table doesnt work
Author: Lea (Guest)
Hi All,
i am currently reading different adc values fromm a Atmega32. The ADC
Value should ne used to look into a LUT and then display the Result out
of the Table via RS232.
The Table looks like
// NTC Tabelle
unsigned long
ntctable[911]={525,427,380,350,329,313,300,289,279,271,264,258,252,247,2
42,
238,234,230,227,223,220,217,215,212,209,207,205,203,201,199,197,195,193,
192,190,188,187,185,184,
182,181,180,179,177,176,175,174,173,172,171,170,169,168,167,166,165,164,
163,162,161,160,160,159,
158,157,156,156,155,154,153,153,152,151,151,150,149,149,148,148,147,146,
146,145,145,144,143,143,
142,142,141,141,140,140,139,139,138,138,137,137,136,136,135,135,134,134,
134,133,133,132,132,131,
131,131,130,130,129,129,129,128,128,127,127,127,126,126,126,125,125,124,
124,124,123,123,123,122,
122,122,121,121,121,120,120,120,119,119,119,119,118,118,118,117,117,117,
116,116,116,116,115,115,
115,114,114,114,114,113,113,113,113,112,112,112,111,111,111,111,110,110,
110,110,109,109,109,109,
108,108,108,108,107,107,107,107,107,106,106,106,106,105,105,105,105,104,
104,104,104,104,103,103,
103,103,102,102,102,102,102,101,101,101,101,101,100,100,100,100,100,998,
996,994,992,990,988,987,
985,983,981,979,977,975,973,971,969,967,966,964,962,960,958,956,954,953,
951,949,947,945,944,942,
940,938,937,935,933,931,930,928,926,924,923,921,919,918,916,914,913,911,
909,907,906,904,903,901,
899,898,896,894,893,891,890,888,886,885,883,882,880,878,877,875,874,872,
871,869,868,866,864,863,
861,860,858,857,855,854,852,851,849,848,846,845,843,842,840,839,837,836,
835,833,832,830,829,827,
826,824,823,822,820,819,817,816,815,813,812,810,809,808,806,805,803,802,
801,799,798,797,795,794,
792,791,790,788,787,786,784,783,782,780,779,778,776,775,774,772,771,770,
768,767,766,765,763,762,
761,759,758,757,756,754,753,752,750,749,748,747,745,744,743,742,740,739,
738,736,735,734,733,732,
730,729,728,727,725,724,723,722,720,719,718,717,716,714,713,712,711,709,
708,707,706,705,703,702,
701,700,699,697,696,695,694,693,691,690,689,688,687,686,684,683,682,681,
680,679,677,676,675,674,
673,672,670,669,668,667,666,665,663,662,661,660,659,658,657,655,654,653,
652,651,650,649,647,646,
645,644,643,642,641,640,638,637,636,635,634,633,632,631,629,628,627,626,
625,624,623,622,621,619,
618,617,616,615,614,613,612,611,610,608,607,606,605,604,603,602,601,600,
599,597,596,595,594,593,
592,591,590,589,588,587,585,584,583,582,581,580,579,578,577,576,575,574,
572,571,570,569,568,567,
566,565,564,563,562,561,560,558,557,556,555,554,553,552,551,550,549,548,
547,546,545,543,542,541,
540,539,538,537,536,535,534,533,532,531,530,528,527,526,525,524,523,522,
521,520,519,518,517,516,
515,514,512,511,510,509,508,507,506,505,504,503,502,501,500,499,498,496,
495,494,493,492,491,490,
489,488,487,486,485,484,483,482,480,479,478,477,476,475,474,473,472,471,
470,469,468,467,465,464,
463,462,461,460,459,458,457,456,455,454,453,451,450,449,448,447,446,445,
444,443,442,441,440,438,
437,436,435,434,433,432,431,430,429,428,426,425,424,423,422,421,420,419,
418,417,415,414,413,412,
411,410,409,408,407,406,404,403,402,401,400,399,398,397,395,394,393,392,
391,390,389,388,387,385,
384,383,382,381,380,379,377,376,375,374,373,372,371,369,368,367,366,365,
364,362,361,360,359,358,
357,356,354,353,352,351,350,348,347,346,345,344,343,341,340,339,338,337,
335,334,333,332,331,329,
328,327,326,325,323,322,321,320,318,317,316,315,314,312,311,310,309,307,
306,305,304,302,301,300,
299,297,296,295,293,292,291,290,288,287,286,284,283,282,281,279,278,277,
275,274,273,271,270,269,
267,266,265,263,262,261,259,258,257,255,254,252,251,250,248,247,246,244,
243,241,240,239,237,236,
234,233,231,230,228,227,226,224,223,221,220,218,217,215,214,212,211,209,
208,206,205,203,202,200,
199,197,195,194,192,191,189,188,186,184,183,181,180,178,176,175,173,171,
170,168,166,165,163,161,
159,158,156,154,153,151,149,147,146,144,142,140,138,136,135,133,131,129,
127,125,123,122,120,118,
116,114,112,110,108,106,104,102,100};
and the function the get the adcvalue :
uint16_t adcwert(uint8_t kanal)
  uint16_t wert = 0;                    //Variable für Ergebnis
deklarieren
  ADCSRA = (1<<ADEN)|(1<<ADPS2)|(1<<ADPS1)|(1<<ADPS0);  //ADEN aktiviert
überhaupt erst den internen ADC-Wandler, ADPS2 bis ADPS0 stellen den
verwendeten Prescaler ein, denn die Wandlerfrequenz muss immer zwischen
50 und 200 kHz liegen! Der Prescaler muss bei 16MHz also zwischen 80 und
320 eingestellt werden, als einzige Möglichkeit bleibt hier 128 (=alle
auf 1).
  ADMUX = kanal;
  //ADMUX = (1<<REFS1)|(1<<REFS0);            //Einstellen der
Referenzspannung auf "extern", also REFS1 und REFS0 auf "0" - daher
auskommentierte Zeile
  ADCSRA |= (1<<ADSC);                  //nach Aktivierung des ADC wird
ein "Dummy-Readout" empfohlen, man liest also einen Wert und verwirft
diesen, um den ADC "warmlaufen zu lassen"
    while(ADCSRA & (1<<ADSC)) {}              //auf Abschluss der
Konvertierung warten
  wert = ADCW;                      //ADCW muss einmal gelesen werden,
sonst wird Ergebnis der nächsten Wandlung nicht übernommen.
  /* Eigentliche Messung - Mittelwert aus 4 aufeinanderfolgenden
Wandlungen */
  wert = 0;
  for(uint8_t i=0; i<4; i++)
    ADCSRA |= (1<<ADSC);        //eine Wandlung "single conversion"
starten
    while(ADCSRA & (1<<ADSC)) {}    //auf Abschluss der Konvertierung
warten
    wert = wert + ADCW;            //Wandlungsergebnisse aufaddieren
  ADCSRA &= ~(1<<ADEN);          //ADC deaktivieren
  wert = wert/4;              //Durchschnittswert bilden
  return wert;
the adcvalue call works fine with
analog=adcwert(i); //Messung Analogport [i]
utoa(analog, wort, 10);  sendUSART(wort);sendUSART("\r\n");
//Ausgabe:"[Analogwert] = "
but my call
sendUSART(ntctable[adcwert(i)]);
directing to the table doesnt show any result at all and i currently
dont know whats wrong with it.
Anybody who can help me out ?
Author: Uwe ... (uwegw)
The Mega32 has 2kBytes of SRAM. But your LUT has 911 entries of 4 Bytes
= 3644 bytes, so it's much larger than the SRAM where it is stored...
You shold move the LUT into the Flash memory, and consider storing only
a few values and interpolating the others. And the data type can be
changed to int.
Author: Lea (Guest)
I changed to long coz i thought that i needed 32bit values, but okay
will change back to int.
How do i tell the Atmega to move the Table into the Flash memory using
avrstudio ?
Author: HELPER (Guest)
http://www.nongnu.org/avr-libc/user-manual/group__...
Read about
1) PROGMEM attribute
2) pgm_read_* funktions
