Forum: ARM programming with GCC/GNU tools YAGARTO tool chain on windows xp
von phillip s. (Company: ing.-büro sikasa) (omusindusa)
I have installed the yagarto tool chain according to the howto posted on
the yagarto website. It seems as if i got something wrong. does anybody
know what could be causing the compiler to fail ????????
the following is the contains of my window:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\ENTWICKLUNG\Projects\sihatec\WINDMESSER_2010\INBETRIEBNAHME\RONETIX_p
m9263\ID
E\SAM7X256Test>make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
m9263\ID
E\SAM7X256Test>arm-none-eabi-gcc --version
arm-none-eabi-gcc (GCC) 4.5.2
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
m9263\ID
E\SAM7X256Test>make clean
rm -f ./src/startup.o ./src/low_level_init.o ./src/main.o
rm -f test_ram.elf
rm -f test_ram.map
rm -f test_ram.hex
rm -f test_rom.elf
rm -f test_rom.map
rm -f test_rom.hex
rm -f ./src/low_level_init.c.bak ./src/main.c.bak
rm -f ./src/low_level_init.lst ./src/main.lst
rm -f ./src/startup.s.bak
rm -f ./src/startup.lst
rm -fR .dep
m9263\ID
E\SAM7X256Test>make all
arm-none-eabi-gcc -x assembler-with-cpp -c -mcpu=arm7tdmi -g -gdwarf-2
-Wa,-amhl
s=src/startup.lst   src/startup.s -o src/startup.o
arm-none-eabi-gcc: unrecognized option '-wa,-amhls=src/startup.lst'
cc1.exe: error: unrecognized command line option "-e"
cc1.exe: warning: unrecognized gcc debugging option: _
cc1.exe: warning: unrecognized gcc debugging option: u
cc1.exe: warning: unrecognized gcc debugging option: s
cc1.exe: warning: unrecognized gcc debugging option: e
cc1.exe: warning: unrecognized gcc debugging option: i
cc1.exe: warning: unrecognized gcc debugging option: n
cc1.exe: warning: unrecognized gcc debugging option: t
cc1.exe: warning: unrecognized gcc debugging option: f
make: *** [src/startup.o] Error 1
m9263\ID
E\SAM7X256Test>
von Artan (Guest)
I did the example of YARGATO, but i did not use the command line of the
prompt.
Try to install the eclipse, it's work fine!
von Oliver (Guest)
There is something wrong in your makefile.
The compiler doesn't like
>-Wa,-amhl
>s=src/startup.lst
Oliver
