Forum: µC & Digital Electronics Double pointer "freeze" on uC
Author: Josh (Guest)
Hello folks!
Iam currently working on a project with the XC2785X-104F Controller,
uVision 4 and Keil C166 Compiler.
Within my code i have to work with matrices and several matrix
calculation. Therefor iam working with double pointers, structs and 2
dimensional arrays.
######################## Code snippet ####################
#################################### matrix struct (incl col,row)
typedef struct {
  int  row;
  int  col;
  }  MATHEAD;
typedef struct {
  MATHEAD  head;
  * only the starting address of the following will be
  * returned to the C programmer, like malloc() concept
  double  *matrix;
  }  MATBODY;
typedef  double **MATRIX;
#define  Mathead(a)  ((MATHEAD *)((MATHEAD *)(a) - 1))
#define MatRow(a)  (Mathead(a)->row)
#define  MatCol(a)  (Mathead(a)->col)
############################################# struct to work with
typedef struct {
  MATRIX A, B, C;
        double var;
}structure;
############################################ func to "create" matrices
MATRIX  mat_creat( row, col, type )
int row, col, type;
  MATRIX  A;
  if ((A =_mat_creat( row, col )) != NULL)
    return (mat_fill(A, type));
  else
    return (NULL);
return (A);
MATRIX  _mat_creat( row, col )
int row, col;
  MATBODY  *mat;
  int   i;
   if ((mat = (MATBODY *)malloc( sizeof(MATHEAD) + sizeof(double *) *
row)) == NULL)
    return NULL;//(mat_error( MAT_MALLOC ));
  for (i=0; i<row; i++)
  if ((*((double **)(&mat->matrix) + i) = (double
*)malloc(sizeof(double) * col)) == NULL)
  mat->head.row = row;
  mat->head.col = col;
  return (&(mat->matrix));   //(& )
###################################################### main.c
structure test1;
// value for var
test1.var = 1.234;
// send data via uart to terminal
send_uart(test1.var);                    // works fine
// create a 2x1 matrix with unknown data
test1.A = mat_creat(2,1,UNDEFINED);
// fill matrix with values
test1.A[0][0] = 0x00;                    // <--------- causes uC-freeze
at this point
send_uart(test1.A[0][0]);                // is not delivered
send_uart("TEST\n");                     // is not delivered
##################### END Code snippet ##############################
If i comment that line out (// test1.A[0][0] = 0x00;) everything works
fine.
If not, there is no error nor a warning from the compiler. Just a freeze
on the uC.
Does anybody know where the problem is?
Did anyone make similar experiences??
I hope someone can help me!
thank you!
Author: THaala (Guest)
hi,
because i didn't understand your code depply - i have tested your code
inside devstudio 2010. Except you forgot to post the function mat_fill()
i cannot see any problem. However - do you have had a look to the
assembler output ?
regards ,
T
Hi T!
The code is working now - it was a platform-own function which
initializes the memory management routines and which was missing.
Afterwards i could use malloc etc. and write values to the matrices!
Despite of that, thanks for your work!
