Forum: ARM programming with GCC/GNU tools Position Independent Executable for Cortex M3
von Dan (Guest)
I am working on building my application so it can be executed directly
from flash (on a Stellaris/TI Cortex M3) anywhere within the flash.  Has
anyone done this?  So far this is what I am trying:
Modified the YAGARTO scripts as follows:
For gcc-build:  Added: CFLAGS_FOR_TARGET="-fpie"
CXXFLAGS_FOR_TARGET="-fpie"
For newlib-build: Added: CFLAGS="-fpie"
My bootloader (which is at a fixed location) modifies the vector table
of the application so that all its vectors are pointing to where the
code actually resides.  I also modified the startup code so that data
section is updated from the correct location of flash.
The problem I am still having is that when my code executes it seems
that all my data is now been changed to be relative the PC.  I want my
code to position independent but I would like to keep the data at the
same locations in the internal sram.   So far I am not linking with -pie
option as when I do my code does not execute at all.  I suspect that I
may need to link with -pie as it seems to add a .dynamic section (in my
data section) to my map file which might be necessary.  I am not sure if
I need to make modifications to the .dynamic section to have it point to
the correct locations in flash in the startup code.
