Forum: ARM programming with GCC/GNU tools ADC interrupt problem in LPC2138
von kamil bahadir (Guest)
Hi!
I am using yagarto last ver. in my project. normaly if i use timer0
interrupt in project, everything ok! timer0 is working.(the LED is
blinking!!)
if i use two interrupt in system (timer0 and A/D0 ) the system is
halting.
the code as below,
cpu: LPC2138
#define IRQ_MASK (~0x000000C0)
void tc0_IRQ(void) __attribute__((interrupt("IRQ")));
void adc0_IRQ(void) __attribute__((interrupt("IRQ")));
void EnableIRQ(void)
  _SET_CPSR(_GET_CPSR() & IRQ_MASK);
static inline unsigned _GET_CPSR(void)
  unsigned long retCode;
  asm volatile (" mrs  %0, cpsr" : "=r" (retCode) : );
  return retCode;
static inline void _SET_CPSR(unsigned value)
  asm volatile (" msr  cpsr, %0" : : "r" (value)  );
void vectorinit (void)
#define VICVectCntl0_ENABLE (1<<5)
#define VIC_Channel_Timer0  4
#define VIC_Channel_adc0  18
    // setup timer0 for IRQ
  // set interrupt as IRQ
  VICIntSelect &= ~(1<<VIC_Channel_Timer0);
  VICIntEnable |=  (1<<VIC_Channel_Timer0);// Enable Timer0 Interrupt
  VICIntEnable |=  (1<<VIC_Channel_adc0);
  // assign VIC slot
  VICVectCntl0 = VICVectCntl0_ENABLE | VIC_Channel_Timer0;// use it for
Timer 0 Interrupt
  VICVectCntl1 = VICVectCntl0_ENABLE | VIC_Channel_adc0;
  VICVectAddr0 = (unsigned long )tc0_IRQ;// set interrupt vector in  0
  VICVectAddr1 = (unsigned long )adc0_IRQ;// set interrupt vector in 1
  /* Enable interrupts */
  EnableIRQ();
void adc0_IRQ (void)
#define VIC_Channel_adc  18
unsigned int r,ch;
     VICVectAddr = 0x00000000;       // clear this interrupt from the
VIC
  r = AD0DR; // Read Data Register and clear DONE flag
  ch = (r >> 24) & 0x07; // which channel was converted
  ADCresult0[ch] = (r>>6) & 0x03FF; // bit 6:15 is 10 bit AD value
:Some code in here....
void tc0_IRQ (void)
:some code in here...
interrupt from the VIC
     T0IR |= 0x00000001;
 void init_adc0(unsigned char clk_div){
 PINSEL0 |= 0x00003C00; // P0.5, P0.6 setup for AD0.7, AD1.0
 PCONP |= 0x00001000;   /*Power on the A/D converter 0 */
                          // AD0CR = 0x00200604; // enable ADC, 11
clocks/10 bits, ADC clock = 4.286MHz
   AD0CR = ( ((clk_div-1))<<8 ) | pdn_bit  ; /* | (1<<ch) configuerthe
A/D control register of A/D 0  with clock = PCLK/(14+1) = 3.8Mhz
  // power up
   AD0CR |= 0x00010000;    // start burst mode
int main(void)
some code.......
init_adc0(14); /*pass channel number and clkdiv*/
init_adc1(14);
Best regrads
kamil
