Forum: FPGA, VHDL & Verilog force/release statements
Author: John Edwards (edwards)
Hi all,
I am testing force and release statements with icarus verilog version
0.9.3.
I am simulating a 1-bit full adder with primitive gates. The drawing is
attached with FA.jpg.
The code for this full adder is:
 * 1-bit Full Adder with primitive gates
 * Sum = a & b & c_in, between #15 and #35
 module fullAdder(c_in, a, b, c_out, sum);
  input c_in, a, b;
  output c_out, sum;
  wire n1, n2, n3;
  xor x1(n1, a, b);
  xor x2(sum, n1, c_in);
  and a1(n2, c_in, n1);
  and a2(n3, a, b);
  or o1(c_out, n2, n3);
 endmodule
 module stimulus;
  reg CIN, A, B;
  wire COUT, SUM;
  integer handle1;
  //Monitor output from the full adder
  initial begin
    $display("\t\tTime\tCIN\tA\tB\tCOUT\tSUM");
    $monitor($time,"\t%b\t%b\t%b\t%b\t%b", CIN, A, B, COUT, SUM);
  end
  fullAdder FA(.c_in(CIN), .a(A), .b(B), .c_out(COUT), .sum(SUM));
  initial begin
    #15 force SUM = A & B & CIN;
    #20 release FA.sum;
  end
  //Monitor the output of FA
  initial begin
    CIN = 0; A = 0; B =0;
    #5 CIN = 0; A = 0; B = 1;
    #5 CIN = 0; A = 1; B = 0;
    #5 CIN = 0; A = 1; B = 1;
    #5 CIN = 1; A = 0; B = 0;
    #5 CIN = 1; A = 1; B = 1;
    #5 CIN = 1; A = 1; B = 0;
  end
 endmodule
I wanted to force sum between time 15 and 35 units to a & b & c_in as
seen above in the stimulus code. But when I run the code, the output I
get is:
Time Cin A B COUT SUM
 0  0  0  0  0  0
 5  0  0  1  0  1
10  0  1  0  0  1
15  0  1  1  1  0
20  1  0  0  0  0
25  1  1  1  1  0  <----- SUM = A & B & Cin
30  1  1  0  1  0
35  1  1  1  1  1
As you can see that at time 25 units the output should be 1.. but I get
output 0. Can anyone see where am I making the mistake?
Thanks,
Edwards
Author: Harald Fluegel (Guest)
Hi Edwards,
As far as I can judge this the simulator behaves correct. Maybe you want
to do something different but your test bench forces the wire SUM to the
result of the expression A & B & CIN at time point 15. The wire SUM is
forced up to time point 35. The release statement releases a different
signal but due to the port collapsing of Verilog it's obviously the same
signal.
Maybe you can describe in words what you want to do? And why.
Cheers,
Harald
Hi Harald,
Thanks for the reply.
My intention is to force SUM signal to (A & B & CIN) between 15 and 35
units.
I am a beginner at Verilog, and I am new to force/release statements. So
I wanted to test these statements out in Verilog.
I suspect the output SUM is being forced to 0 instead of (A & B & CIN)
between 15 and 35. As you can see at time 25 units in the simulation
output, A = 1, B = 1, CIN = 1... but SUM = 0.
Perhaps I am making a fundamental mistake, but SUM(at #25)
= A & B & CIN = 1 & 1 & 1 = 1
I tested the #35 release SUM instead of #35 release FA.sum. The port
collapsing does make SUM and FA.sum the same signal.
Edwards
Hi Edwards,
Well, the force/release statements are supposed to clamp signals to a
specific value instead of letting them operate as usual.
Yes. The force statement executed at time 25 clamps the signal SUM to
the (static) result of the expression A & B & CI, what is 0 at this
time. The expression is not re-evaluated as one of the input changes.
SUM is claped to this static value until it's released.
The use of force/release does not make much sense in that scenario.
Harald
Hi Harald,
I tested out the program as you mentioned and it does assign SUM to a
static value calculated at time #15.
That explains what is going on. Thanks for your help :)
Edwards
Author: Marcus Harnisch (mharnisch)
I am afraid it doesn't. The force/release in this context is a
"procedural continuous assignment" (IEEE 1364-2005, sec. 9.3) which
means: "[...]if any variable on the right-hand side of the assignment
changes, the assignment shall be reevaluated while the assign or force
is in effect."
A major commercial simulator returns this:
#     Time  CIN  A  B  COUT  SUM
#        0    0  0  0     0    0
#        5    0  0  1     0    1
#       10    0  1  0     0    1
#       15    0  1  1     1    0
#       20    1  0  0     0    0
#       25    1  1  1     1    1
#       30    1  1  0     1    0
#       35    1  1  1     1    1
Kind regards
Marcus
http://www.doulos.com/
Hmm...
Thanks for pointing that out.
From what I have read, force/release statements are supposed to act
differently on nets and registers.
For nets, they should be reevaluated (like in this case for SUM, i
think). For regs, they should be evaluated only once(at force) and the
same value is forced.
I made a very simple AND module to test it out:
 module Top;
  reg a;
  reg b;
  wire A;
  wire B;
  wire c;
  //Testing force and release for wire arguments
  assign A = a;
  assign B = b;
  assign c = A | B; //All wires in this expression. Force
                    //statement should definitely reevaluate
  initial
  begin
    $monitor($time, "\t%b\t%b\t|%b", a, b, c);
  end
  initial
  begin
    a = 1'b0; b = 1'b0;
    #5 a = 1'b1; b = 1'b1;  <------ #5
    force c = A & B;
    #5 a = 1'b1; b = 1'b0;
    #5 a = 1'b0; b = 1'b1;
    #20 release c;
  end
 endmodule
Note: Don't get confused with c = A & B. I just wanted all arguments and
assigned LHS to be wires.
If I execute the case above, I always get 1 as below:
#00     0  0  |  0
#05     1  1  |  1       <---- force start
#10     1  0  |  1
#15     1  1  |  1
#25     1  1  |  1
#30     0  1  |  1
#35     1  0  |  1
#55     1  1  |  1       <---- release
If I change the test case {1 1} at time #5 to {1 0}, I get all 0 until
release:
i.e.
#00     0  0  |  0
#05     1  0  |  0
#15     1  1  |  0
#25     1  1  |  0
#30     0  1  |  0
#35     1  0  |  0
#55     1  1  |  1
ICARUS verilog is treating both regs and nets the same way, forcing both
of them to a static value evaluated at #5.
Can someone confirm this reasoning?
Edwards
Hello,
There is a way to obtain the required behaviour from force/release
statements. Referring to the code, I posted in my first post(4-bit Full
adder), instead of writing the statements in the 'Top' module:
initial begin
    #20 release FA.sum;
end
We should write it as:
wire expr;
assign expr = A & B & CIN
initial begin
    #15 force SUM = expr;
    #20 release FA.sum;
end
This appears to behave correctly for Icarus Verilog version 0.9.3. The
bug report status is still open. I have borrowed this from the comments
section of the bug report on Source Forge tracker here:
http://sourceforge.net/tracker/index.php?func=deta...
entitled "Procedural continuous assign or force is only evaluated once -
Thanks
Edwards
Author: Uwe Bonnes (Guest)
Isn't this best discussed on the icarus/geda mailing list?
Perhaps yes, as it appears to be an icarus simulator based issue.
Anyhow, it would be nice to have these posts here, just incase somebody
else comes across this issue.
Edwards
John Edwards wrote:
> For nets, [the RHS expression of a force statement] should be
> reevaluated (like in this case for SUM, i think). For regs, they
> should be evaluated only once (at force) and the same value is
> forced.
Where did you read that? The main difference between a var and a net
in this context is the behavior when released again. A var keeps its
(forced) value while a net assumes the resolved value of all its drivers
immediately.
Marcus
Hi Marcus,
Correct again. I was under the wrong impression that reg would evaluate
RHS expression only once with a value forced on it until it is released,
but they also re-evaluate expressions assigned to them.
I was confused by the wording in my textbook:
   "The register var will continue to store the forced value after being
released, but can then be changed by a future procedural assignment."
My apologies. Thanks for pointing that out.
Edwards
  • [vhdl]VHDL code[/vhdl]
