Forum: ARM programming with GCC/GNU tools Yagarto/LPC2388
Author: Bruce Graham (Company: Wadia) (papabravo)
Has anybody done a project template with a hardware header, makefile,
and linker script for an LPC2388 using Yagarto?  If not I'll try making
one from scratch and post it when I get it working.
I suggest that you do not start from scratch but use an
example-application for a similar device as template. Free header-files
with register-defintions for the target should be available from
nxp.com.
If you are done it might be good to create a small page in the Wikki of
this site (menu at the left -> "Articles"). The acticle-collection/Wikki
is a better place for "persistent" information than a message in this
forum.
Several versions of a suitable header file can be found by googling
"LPC23xx.h".  The next problem is the the startup code and linker
control files.  I was hoping to avoid doing those by modifying a similar
project if one had already been done and published.
Author: Christian H. (blueicehaller)
Hello,
I want the same thing. The µC is LPC2388, too.
Until now I used ULINK2 and uVision3.
I have existing c projects with startup.s
which now should run under Eclipse with Yagarto.
For testing I will use ULINK2.
One Source for Info http://www.yagarto.de/howto/yagarto2/index.html
Is it possible realize this plan?
webmaster@embdev.netContactAdvertising on EmbDev.net
