Forum: µC & Digital Electronics Pin Change Interrupt - External Interrupt with Internal Interrupt
von Nice C. (crazyinterrupts)
Here in the program, am cycling through LEDs using timer interrupt & if
someone presses a switch, it should stop the first interrupt & trigger
second one that should lit the led according to the switch pressed.
Here, am a little confused which interrupt is being called. I referred
some books for Pin Change Interrupt & wrote a few lines for setting
PCMSK2. The output am getting is "initially all leds are cycling, when a
switch is pressed...cycling of leds stops & starts over again (which
means that program is reading input, just not triggering the second
interrupt). It doesn't stop or pause & doesn't lit subsequent led."
Could anyone help, please?
#include <avr/io.h>
#include <avr/interrupt.h>
volatile unsigned int intrs, i=1;
void enable_ports(void);
void delay(void);
extern void __vector_23 (void) _attribute_ ((interrupt));
extern void __vector_25 (void) _attribute_ ((signal));
void enable_ports()
    DDRB = 0xff;   //PORTB as output for leds
    PORTB = 0xff;
    DDRK = 0x00;  //PORTK as input from switches
    PORTK |= PINK_MASK;
    PCMSK2 = PINK_MASK;     //ENABLE PCMSK2, Setting interrupts
    PCICR = 0x04;
    PCIFR = 0x04;
    TCCR0B = 0x03;      //Setting TIMER
    TIMSK0 = 0x01;
    TCNT0 = 0x00;
    intrs = 0;
    intrs++;
    if(intrs > 60)
        intrs = 0;
        PORTB = (0xff<<i);
        i++ ;
        if(i == 10 )
            PORTB = 0xff;
            i = 1 ;
    sei();
    unsigned char switches;
    switches = ((~PINK) & (PINK_MASK)); //Reading from switches
    if(switches & (1<<PINK0))
        PORTB = (PORTB<<PINK0);
    else if (switches & (1<<PINK1))
        PORTB = (PORTB<<PINK1);
    else if (switches & (1<<PINK2))
        PORTB = (PORTB<<PINK2);
    else if (switches & (1<<PINK3))
        PORTB = (PORTB<<PINK3);
    else if (switches & (1<<PINK4))
        PORTB = (PORTB<<PINK4);
    else if (switches & (1<<PINK5))
        PORTB = (PORTB<<PINK5);
    else if (switches & (1<<PINK6))
        PORTB = (PORTB<<PINK6);
    else if (switches & (1<<PINK7))
        PORTB = (PORTB<<PINK7);
int main(void)
    enable_ports();
    sei();
    while(1)
