Forum: ARM programming with GCC/GNU tools Unwanted remove of unused variables with GCC
von Mattias (Guest)
I have a application where I need to declare a couple of variables in
RAM but they will not be used in the application. I then use the RAM
addresses for the variables, to change there values via a communication
port.
Unfortunately GCC remove the variables if I don't use them, and I don't
want to add "fake use" like "if(var_name){}"
I don't use any optimizing at the moment, the variables are removed
anyway.
Is there a way to keep them?
Thanks
/Mattias
von Jörg W. (dl8dtl) (Moderator)
Your fake use wouldn't help anyway, as it will be optimized away
as well.
Not sure how a "communication port" could change SRAM data without
the intervention of code, anyway, what you're probably looking for
is
__attribute__((used))
von Johann L. (gjlayde)
I don't quite understand what you are doing... you use the address of a
variable the variable is used (in general) and the object must not be
canceled out. Can you give a small example in C to make it clear?
> is
AFAIR this helps for functions, not for vars.
von Andreas B. (Guest)
The attribute does help for variables:
> `used'
>      This attribute, attached to a variable, means that the variable
>      must be emitted even if it appears that the variable is not
>      referenced.
>> `used'
>>      referenced.
Which version of gcc does this refer to?
Ah, got me there. I just looked in the current docs I had. Looking
through the docs on gcc.gnu.org, it appears the 'used' attribute for
variables appeared in version 4.2.
von Philipp B. (philipp_burch)
Another way to ensure that the variables exist could be to declare them
as volatile. Since they could be changed by hardware (for whatever
reason) this should be the appropriate method. The problem sounds a bit
strange to me, however.
von Big W. (tylr2005)
Hi
Have you try the "volatile" keyword?
