Forum: ARM programming with GCC/GNU tools structs in MAP-file
von Mattias Enstedt (Guest)
Is there a way to get more information of struct members name, address
and size in the MAP-file? Today I only get the struct variable name and
its address.
typedef struct
    u16_t member1;
    u16_t member2;
} test_t;
extern volatile test_t test_parameters;
mapfile today
"COMMON         0x2000032c       0x?? C:\parameters.o
                0x2000032c                test_parameters
                0x200003??                . = ALIGN (0x4)
                0x200003??                _ebss = .
                0x200003??                PROVIDE (end, _ebss)
                0x200003??                PROVIDE (_end, _ebss)"
I'm using Ride 7 and GCC.
Best regards
Mattias
von kbuchegg (Guest)
> address and size in the MAP-file? Today I only get the struct
> variable name and its address.
Ususally not, since all structure member accesses are already completely
resolved by the compiler, when the linker sees the individual parts and
creates the map file.
Is it possible to add some compiler/linker directives or comments in
source code that will bring the struct members to the MAP-file?
/Mattias
What is it, that you want to do?
The information you are seeking, is present in the debug information,
but it depends on what you want to do, if it is on any use to you.
von Huch (Guest)
My magic wand points to: pragma pack
