Forum: ARM programming with GCC/GNU tools ARM gcc cross compile in window
von Yee Y. (Company: Infowave) (armgcc)
I am using ATMEL microcontroller (ARMS 7) and using Embest IDE.
I want to use GCC to compile the source codes that have been written
into a dll and lib files.
And can someone recommend me the relevant websites which gcc tools and
software that I should download and the required steps...
Should I use MinGW or Cygwin since i want to do a cross compilation in
Windows environment.
Your help is appreciated
thanks
Yee Yee wrote:
> Hi,
Is an Operation-System running on the target? It is possible to create a
library (collection of object codes, "lib file") and later statically
link functions from the library to an application running on
"bare-metal" (without OS). Shared libraries and late linkage like with
"DLL files" on MS Windows are usually provided by the OS (loader,
filesystem, memory-management, ...).
For libraries ("lib files") the needed tools are already included in the
usual packages of GNU cross-toolchains (gcc from the
compiler-collection: .c->.o and ar from the binutils: *.c->.a/.lib).
There is not need for MinGW or Cygwin since ready-mode GNU
cross-toolchains are available for MS Windows (Yagarto, DevkitARM, CS
G++ for ARM, Ronetix...). As far as I know the Embest IDE (never used
it) also comes with a toolchain. If you want to build your own
cross-toolchain you may look into the SVN/CVS/git of DevkitPro and
Yagarto on sf.net.
Hi, Martin, thanks for the reply.
I am at a loss about how to get this project forward as I am not
familiar with open source Gcc programming.
An OS system will be ideal.
We need some sort of coding management. We wanted to use gcc to make
certain standard codes modular that we wrote by creating standard
library and then doing documentation. So, in future, the developers need
not look at the entire coding and attach the cpp source code to the
project. They just need to link the library file and then just call the
function.
Embest doesn't allow us to create dll and library files.
My background is mechanical and hv done a fair bit of embedded
programming. But in the area of creating library files, coding design, i
am at a loss as to how i can begin the project as I am not a computing
student.
I notice that there is also a Visual-MinGW, which is a IDE environment?
Can it be used to compile, build and create lib files for ARMS coding?
Your help and advice is appreciated.
thanks
Martin Thomas wrote:
> Yee Yee wrote:
>> Hi,
> Yagarto on sf.net.
btw, what does cross-toolchain mean?
It seems like there are a couple of different gcc software... What's the
difference? Any good websites with a good installation and get started
tutorial?
So, u think I should use software like DevkitArm, CS G++ for ARM etc???
Depends on the application.
> function.
A "lib file" as a collection of object-code should be o.k. for this. The
developers get the library file and one or more header-files (.h).
The IDE might not support the creation of library files but the tools in
the background should. Did you ask Embest?
> student.
I don't know since I'm usually using Makefiles for this. How library
files can be created from an IDE should be mentioned in the IDE's
documentation/online-help.
The basic idea is to use the compiler to create object-code from
source-code and the archiver to collect the object-codes into a library
("lib-file"). When using GNU tools the usual file-extension is ".a" and
the filename starts with "lib".
Example: 2 source-files egalA.c and egalB.c get compiled into
object-code in files egalA.o and egalB.o. Later the object codes are
collected into a library file libmylib.a. CS G++ used here but the
concept is similar with other toolchains based on GNU sources. There are
much more options and features but this should give the basic idea.
arm-none-eabi-gcc egalA.o egalA.c
arm-none-eabi-gcc egalB.o egalA.c
arm-none-eabi-ar rcs libmylib.a egalA.o egalB.o
The library can later be used by passing -lmylib as parameter when
linking the application. An IDE should call compiler/archiver similar to
this when selecting something like "create library" from the GUI.
There should be an official definition somewhere in the net. Basically a
collection of programs to create applications for a target with a
different OS and/or architecture (example ARM7 no OS) then the machine
on which the these programs run (example MS-Windows on x86).
> difference?
Main difference is the target. The usuage is always similar. For ARM and
Linux OS search for an arm-*-linux toolchain, for ARM "bare metal"
search for arm-*-elf ("old" ABI) or arm-*-eabi ("new" ABI). Go to
gcc.gnu.org and read a little bit on GCC targets for further
information.
> tutorial?
Did you check the "sticky" post of this forum?
DevkitARM, Yagarto and CS G++ lite are very similar: toolchain to create
"bare metal" applications for targets with ARM core. The IDE might
already include a GNU toolchain and use it in the background.
Thanks, Martin for replying to my post.
Appreciate your help.
