Forum: ARM programming with GCC/GNU tools Explicitly naming loop labels
von Miguel Pires (Guest)
Hello.
I was wondering if it is possible to explicitly attribute name to the
labels that mark a loop entry.
By default, those are named something like ".L2".
What I would like is to be able to do something like
asm ("my_loop_label")
for(i=0...)
and the compilation would yield ARM assembly with that label name at the
loop entry point.
Is something like that possible?
If not, do you happen to know a way to detect loops in ARM assembly?
Thank you.
von Johann L. (gjlayde)
Did you check out asm goto?
http://gcc.gnu.org/onlinedocs/gcc/Extended-Asm.html
This if for gcc >= 4.5 and said to be unstable...
Then, if you program GNU-C building a C-label and passing it to the
assembler should work. However, I never tried that, look hackish, works
for local labels only and you probably have to jump indirect.
Maybe most convenient will be to just return some value and jump
conditionally on that instead of jumping from inside asm.
