Forum: µC & Digital Electronics Simulating FFT with PIC32 Clock system
von Kamal A. (ellgafsi)
Hello,
I am studying the book Programming 32-bit Microcontrollers  in
C:Exploring the PIC32 by Lucio Di Jasio and I am having a problem
simulating the FFT Program in chapter 7 Running page 152-167.
The Problem is that I become different result.
After setting the Breakpoint on the line containing the while(1) loop
and pressing Run, a become different Result for t and f  variables.
On other hand the result of the simulation of Mr. Di Jasio (Figure 7.7)
are:
t = 6142543
f = 0.170626194444444
I am using a  PIC32 Ethernet Starter kit with a PIC32MX795512L
µcontroller. Is that good enough for the Simulation???
On page Page 159 Mr. Di Jasio  mention about combining Timer 4 and Timer
5 to capture the required Time, but he has not mention where we put the
Code Snippet. I put it on the run.c (main) but I am not sure about the
correctness of the order of my Implementation.
I read the Updates Section on the PIC32 Website and I tried to adjust my
Code (Configuration Bits Setting on the #Pragmas)
to the Hardware Specification but it does not work.
I changed the Configuration Bits Settings as the Author suggest in the
Book but also that to does no Effect. So a Reset them to the Default.
I've also attached the full Project zipped and 2 Screenshot of my
Configuration Bits Settings and watch window.
Antworten auf Deutsch sind auch herzlich willkommen :-)
Danke für eure Unterstützung!
Ellgafsi
von oways (Guest)
i have problems in the code as you..
so if you solve yours pls inform me how.
