Forum: ARM programming with GCC/GNU tools LD: Use same input section in multiple output sections
von Oliver B. (irq)
In Short: Is it possible, to tell the linker, to place the same piece of
code in multiple flash locations?
What I'm trying to do is, to write a linker script, to run an
application either in "standalone mode" or with a bootloader installed,
for in application programming.
For this I want the isr vector table to be located at the controllers
default location - where it gets overridden, if the bootloader is
flashed - and in the applications section, where the bootloader jumps
to, when it is finished.
This is how the parts in my linker script look like:
[code]
.bootloader :
  . = ALIGN(0x80);     /* PM0056, Rev.1 (4/2009), 4.3.3 */
  KEEP(*(.isr_vector)) /* Initial isr table. It gets overridden, as
                          soon as bootloader is installed. */
} >BL
.application :
4.3.3 */
  _app_isr_vectors_offset = . - 0x08000000;
  KEEP(*(.isr_vector))                      /* This is the application
                                               vector table to use, when
} >APP
The result is, that the KEEP(*(.isr_vector)) in the .application section
produces no output in the binary file. Maybe already used input sections
are marked as used and cannot be inserted again?
I searched the GNU LD manual, but did not find a hint how to do this.
Can you tell me, if this is possible and if yes, how?
Thanks!
