Forum: ARM programming with GCC/GNU tools How to generate debug symbols for custom linker file
Author: Tat Wan (Company: Universiti Sains Malaysia) (tcwan)
I'm trying to use a JLink JTAG to develop assembly code for a LEGO
Mindstorms NXT (Atmel AT91SAM7S256). However, the code base uses a
custom linker configuration file (attached).
I have two development platforms, Mac OS X and Windows based (Yagarto
Toolchain + Eclipse + JLink GDB Server)
The problem is that after the code is built and linked,
arm-none-eabi-gdb will always complain (example taken from Mac OS X
version, but similar results were obtained in Windows):
iMac-TCWan:tests tcmac$ arm-none-eabi-gdb tests_rxe.elf
GNU gdb (GDB) 7.1
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-apple-darwin10.4.0 --target=arm-none-eabi".
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>...
Reading symbols from /Users/tcmac/gitrepo/nxos-aholler/nxos/systems/tests/tests_rxe.elf...(no debugging symbols found)...done.
I verfied that if I objdump the tests_rxe.elf file, there is a symbol
table.
Linking with the default linker (i.e., without -T option) generates
debugging symbols recognized by gdb.
iMac-TCWan:tests tcmac$ arm-none-eabi-gdb tests_rxe.eabi
GNU gdb (GDB) 7.1
Reading symbols from /Users/tcmac/gitrepo/nxos-aholler/nxos/systems/tests/tests_rxe.eabi...done.
arm-none-eabi-objdump -rD of the custom-linker generated executable is
as follows:
iMac-TCWan:tests tcmac$ fgrep Disassembly tests_rxe.elf.objdump
Disassembly of section .rxe_header:
Disassembly of section .vectors:
Disassembly of section .rxe_init:
Disassembly of section .data:
Disassembly of section .text:
Disassembly of section .bss:
Disassembly of section .stack:
arm-none-eabi-objdump -rD of the default linker generated executable is
as follows:
iMac-TCWan:tests tcmac$ fgrep Disassembly tests_rxe.eabi.objdump
Disassembly of section .comment:
Disassembly of section .debug_aranges:
Disassembly of section .debug_pubnames:
Disassembly of section .debug_info:
Disassembly of section .debug_abbrev:
Disassembly of section .debug_line:
Disassembly of section .debug_frame:
Disassembly of section .debug_str:
Disassembly of section .debug_loc:
Disassembly of section .debug_pubtypes:
Disassembly of section .debug_ranges:
Disassembly of section .ARM.attributes:
There are no .data, .text, .bss, or .stack sections in this version.
How can I generate the debugging symbols when using a custom linker
configuration file?
Author: Andreas B. (Guest)
  /* Discard anything not mapped at this point. */
  /DISCARD/ : {
This part of the linker script discards all sections not referenced in
the script up to that point and that includes all the debug sections.
I don't know how the code uploader works in your case but it should be
able to recognize that these sections (and others) do not need to be
uploaded and ignore them. Try simply removing the lines I quoted.
Hi Andreas,
You are right. When I removed the "/DISCARD/" directive section, it
generated the debug symbols. Thank you for the solution.
