Forum: ARM programming with GCC/GNU tools custom board libc.a - how to link in?
von Sledge H. (sledge)
Hello,
I have got here an ARM custom board, with only rootfs available (no
source code..)
Trying to cross-compile vncviewer for it with CodeSourcery's G++ Lite.
libc.a in G++Lite shouts errors such as:
.../CodeSourcery/Sourcery_G++_Lite/bin/../lib/gcc/arm-none-eabi/4.4.1
/../../../../arm-none-eabi/lib/libc.a(lib_a-isattyr.o):
In function `_isatty_r':
isattyr.c:(.text+0x18): undefined reference to `_isatty'
 (_write, _fstat, _exit etc)
The answer I got from this link
(http://www.embeddedrelated.com/groups/lpc2000/show/48415.php) says:
You would normally provide application specific versions of these
functions yourself. If you don't need the functions then they can be
stubbed out.
vnc obviously needs those functions, and I found their implementations
in that custom board's /usr/lib/libc.a
Is there a way to merge nicely the implemented functions in
.../custom-board/rootfs/usr/lib/libc.a and CodeSourcery's libc.a ?
Since I am a noob in autoconf -- how to modify vnc's autoconf config
files to enable this?
What I tried so far:
1.Overwriting custom libc.a over the G++Lite's one, then I would get
errors about unresolved _impure_ptr exports (means those residing only
in the CodeSourcery..)
2.Then I renamed the custom libc.a into libcustomc.a and manually
performed collect2 (ld) on a skeleton project - it worked! But how to
integrate this into autoconf (settings LIBS = -lcustomc in configure.in
did not help)?
And this "rename named conflicts" is by far not elegant anyhow...
So, there must be the way to gently compile complementary functions (and
./configure with CROSS_COMPILE kernel's-working approach, too, but
that's another topic) for us embedded folks out there..
Thanks heaps!
sledge
