Forum: µC & Digital Electronics HD44780 LCD with PIC 18F2550
von Marius (Guest)
I want to control a HD44780 display with a PIC 18F2550 via a 4bit
interface, but my routine doesn't seem to work. I've already looked on
several pic sites but I just can't find my mistakes. So if someone could
look over it, I would be very thankful :).
Thanks in advance
von Tobias (Guest)
look on this page ;) it is explain very easy.
http://www.sprut.de/electronic/lcd/index.htm
von PicArd (Guest)
Hi Maurius,
if you try to switch to 4 Bit Mode you`ve to keep in mind that
the HD Controller is still in 8 Bit Mode.
lcd_init:
         BCF      RS ; put into Comand Mode
  CALL  delay_16ms    ; should be 30 mS for Saftey
  MOVLW  b'00000010'
  MOVWF  PORTB    ;initialize display interface to 4bit
  CALL  lcd_enable
  CALL  delay_100us
  MOVLW  b'00001110'  ;2 rows
  CALL  lcd_sendcommand
  CALL  delay_100us
  MOVLW  b'00001100'  ;Display on
  CALL  delay_100us
  MOVLW  b'00000110'  ;Cursor right, no shift
  CALL  delay_100us
  MOVLW  b'00000001'  ;Clear display
this should work now, please Report
PicArd
von Marius (Guest)
Thanks for your replies but it still doesn't work. I also made the
delays a little bit longer, but that didn't help either.
von PicArd (Guest)
Hi Maurius,
sorry my fault, try this
lcd_init:
  MOVLW  b'00000010'
  CALL  lcd_enable
  CALL  delay_100us
  MOVLW  b'10000010'  ;2 rows
  CALL  delay_100us
  MOVLW  b'00001100'  ;Display on, Cursor off, Blink off
  CALL  delay_100us
  CALL  delay_100us
in my Routines i do a read of the PortB first and store the content in a
FR. Then i add the changed 4 Bit for the LCD and write them back to the
Port.
This prevent a malefunktion of RS E and so forth.
In your Sendcommand Routine the High Nibble is not changed to the I/O
you use.
Better do:
lcd_sendcommand:
  MOVWF  scomm
         MOVLW  b'11110000'      ; High Nibble First
  ANDWF  scomm,w
         MOVWF    TEMP
         SWAPF    TEMP,w          ; HIGH Nibble change to Output Bit
  MOVFW    PORTB
  CALL  lcd_enable
  MOVLW  b'00001111'
  ANDWF  scomm, w
  MOVWF  PORTB
  CALL  lcd_enable
  CALL  delay_100us
  RETURN
The Same you do with the senddata
try it....
PicArd
von Marius (Guest)
I swapped the nibbles so they fit to the I/O Ports I use, but it still
doesn't work :(
von PicArd (Guest)
Hi Marius, got your Name wrong first sorry...
the sendcommand routine with Reading of PortB look like that:
lcd_sendcommand:
  MOVWF  scomm
  ANDWF  scomm,w
         MOVWF    TEMP
         SWAPF    TEMP,f          ; HIGH Nibble change to Output Bit
  MOVFW  PORTB            ; read PortB
  MOVWF  TEMP2            ; Store Temporary
  MOVLW  b'11110000'      ; keep the I/O of PortB (HIGH NIBBLE)
  ANDWF  TEMP2,f          ; remove 4 BIT LCD DATA (LOW NIBBLE)of PORTB
  MOVF   TEMP2,w
  ADDWF  TEMP,w           ; Add the new 4 BIT LCD DATA
  MOVFW    PORTB          ; write to Port
  CALL  lcd_enable
  MOVLW  b'00001111'
  ANDWF  scomm, w
  ADDWF  TEMP2,w
  MOVWF  PORTB
  CALL  lcd_enable
  CALL  delay_100us
  RETURN
this is the best way to get out of conflict with the PORTB High Nibbles
PicArd
von PicArd (Guest)
and don't forget to change the senddata routine as well !
PicArd
von PicArd (Guest)
Hello Marius,
i forgot one important thing....
lcd_sendcommand:
; FIRST put the LCD into Command Modus
  BCF    RS   ; PortB,4 in your Design
; ____________________________________
  MOVWF  scomm
  ANDWF  scomm,w
         MOVWF    TEMP
  MOVF   TEMP2,w
  CALL  lcd_enable
  MOVLW  b'00001111'
  ANDWF  scomm, w
  ADDWF  TEMP2,w
  MOVWF  PORTB
  CALL  lcd_enable
  CALL  delay_100us
  RETURN
and for lcd_senddata:
lcd_senddata:
; FIRST put the LCD into DATA Modus
  BSF    RS   ; PortB,4 in your Design
  MOVWF  scomm
  ANDWF  scomm,w
         MOVWF    TEMP
  MOVF   TEMP2,w
  CALL  lcd_enable
  MOVLW  b'00001111'
  ANDWF  scomm, w
  ADDWF  TEMP2,w
  MOVWF  PORTB
  CALL  lcd_enable
  CALL  delay_100us
  RETURN
These Routines i use in my LCD Applications and they work.
If this fail's try to increase the WAIT Time, this varrys from LCD to
LCD
good luck
PicArd
von Marius (Guest)
Still doesn't work. I also don't understand the sense in reading PORTB?
Anyways my two routines look like this:
lcd_sendcommand
  BCF  RS
  MOVWF  scomm
  MOVLW  b'11110000'
  ANDWF  scomm, 0
  MOVWF  TEMP    ;swap nibbles to fit on the I/O
  SWAPF  TEMP, 1
  MOVF  PORTB, 0  ;read PORTB
  MOVWF  TEMP2
  MOVLW  b'11110000'
  ANDWF  TEMP2, 1
  MOVF   TEMP2, 0
  ADDWF  TEMP, 0
  MOVWF  PORTB
  CALL  lcd_enable
  MOVLW  b'00001111'
  ANDWF  scomm, 0
  ADDWF  TEMP2, 0
  MOVWF  PORTB
  CALL  lcd_enable
  CALL  delay_100us
  RETURN
lcd_senddata
  BSF  RS
  MOVWF  sdata
  MOVLW  b'11110000'
  ANDWF  sdata, 0
30
  MOVWF  TEMP
31
  SWAPF  TEMP, 1
32
  MOVF  PORTB, 0
33
  MOVWF  TEMP2
34
  MOVLW  b'11110000'
35
  ANDWF  TEMP2, 1
36
  MOVF  TEMP2, 0
37
  ADDWF  TEMP, 0
38
  MOVWF  PORTB
39
  CALL  lcd_enable
40
  MOVLW  b'00001111'
41
  ANDWF  sdata, 0
42
  ADDWF  TEMP2, 0
43
  MOVWF  PORTB
44
  CALL  lcd_enable
45
  CALL  delay_100us
46
  RETURN
von Benni L. (sutter_cain)
Which Compiler are you using?
MCC18 Compiler from Micrchip is shipped with a library for the hd44780.
You only had to: #include xlcd.h
There must also be a docu somwhere. Otherwise just look in the Header
itself.
von PicArd (Guest)
Hello Marius,
the sense is simple, If you are using the PortB,7 as Input or Output
a move Instruction does a read of the TRIS instead of the Port and write
the Byte, this can result in "Funny" reaction of your Program later.
IMPORTANT:
Did you switch the PortB Function PIN's to be a explicit I/O on RB0-4 at
the beginning of the program ? Please read the DATASHEET at section 10.2
The Anonciater are set after Power on, you have to switch them to be
an I/O !
PicArd
von PicArd (Guest)
It should be like that:
init:
CLRF PORTB
CLRF LATB
MOVLW h'0E'  ; Switch AN = OFF
MOVWF ADCON1 ;
MOVLW h'00'h ; all PORTB = OUTPUT
MOVWF TRISB
hope that helps
PicArd
von Marius (Guest)
Thank you very much for your help, but that didn't help either :(
von PicArd (Guest)
Ok Marius,
i've got all Parts (18F1250) here to Test your Code, please attach your
full Sourcecode and i will test it tomorrow evening and report the
result back to you.
BTW: i use MPLAB on Windows, i think you are using a Linux compiler?
best regards
PicArd
von Marius (Guest)
Thank you very very much for your help :). Yes i'm using a linux
compiler (gpasm).
Regards,
Marius
von PicArd (Guest)
Hello Marius,
here is my changed version for Test, i will test it tomorrow evening
with
Hardware... but maybe you won't wait and test.
good nigth
PicArd
von SV (Guest)
You could also first test your communicaton protocol directly from a PC.
I had a similar problem and I solved it this way. I made a HEX file that
enables me to control all the PIC18 registers directly from my Windows
application. Only after thorough testing I transfered the programming to
PIC18.
