Forum: ARM programming with GCC/GNU tools LPC1768 CAN1 receive
von Tom (Guest)
Hey,
does anybody have a simple program for this µC for receiving a message
on CAN1?
I tried a lot with some code examples from Keil but I am not be able to
receive a message with a special identifier.
Thanks a lot
von Lutz (Guest)
Have you checked the examples in the folder LPC1700CMSIS/Examples/CAN/*
of the CMSIS Library for the LPC?
von Tom (Guest)
Yes sure but I am not be able to debug it, I am using Cross Studio for
ARM.
My problem is, that i does not exactly now what I have to set and
program.
here is a part of the program I am workin with maybe you know it, I
doesn't know which function i have to set where in my main programm.
 *  can.c:  CAN module API file for NXP LPC17xx Family Microprocessors
 *   Copyright(C) 2009, NXP Semiconductor
 *   All rights reserved.
 *   History
 *   2009.05.27  ver 1.00    Prelimnary version, first Release
 *   13.10.2010  ver 1.1     Änderung bezüglich CAN2
#include "lpc17xx.h"
#include "type.h"
#include "can.h"
/* Receive Queue: one queue for each CAN port */
extern CAN_MSG MsgBuf_RX1;
extern volatile uint32_t CAN1RxDone;
volatile uint32_t CANStatus;
uint32_t CAN1RxCount = 0;
uint32_t CAN1ErrCount = 0;
** Function name:    CAN_ISR_Rx1
** Descriptions:    CAN Rx1 interrupt handler
** parameters:      None
** Returned value:    None
30
31
void CAN_ISR_Rx1( void )
32
33
  uint32_t * pDest;
34
35
  /* initialize destination pointer  */
36
  pDest = (uint32_t *)&MsgBuf_RX1;
37
  *pDest = LPC_CAN1->RFS;  /* Frame  */
38
39
  pDest++;
40
  *pDest = LPC_CAN1->RID; /* ID  */
41
42
43
  pDest++;
44
  *pDest = LPC_CAN1->RDA; /* Data A */
45
46
47
  pDest++;
48
  *pDest = LPC_CAN1->RDB; /* Data B  */
49
50
51
  CAN1RxDone = TRUE;
52
  LPC_CAN1->CMR = 0x04; /* release receive buffer */
53
  return;
54
55
56
57
** Function name:    CAN_Handler
58
59
** Descriptions:    CAN interrupt handler
60
61
** parameters:      None
62
63
64
65
void CAN_IRQHandler(void)
66
67
68
  CANStatus = LPC_CANCR->CANRxSR;
69
  if ( CANStatus & (1 << 8) )
70
71
  CAN1RxCount++;
72
  CAN_ISR_Rx1();
73
74
75
  if ( LPC_CAN1->GSR & (1 << 6 ) )
76
77
  /* The error count includes both TX and RX */
78
  CAN1ErrCount = LPC_CAN1->GSR >> 16;
79
80
  return;
81
82
83
84
** Function name:    CAN_Init
85
86
** Descriptions:    Initialize CAN, install CAN interrupt handler
87
88
** parameters:      bitrate
89
** Returned value:    true or false, false if initialization failed.
90
91
92
uint32_t CAN_Init( uint32_t can_btr )
93
94
  CAN1RxDone = FALSE;
95
96
  LPC_SC->PCONP |= ((1<<13)|(1<<14));  /* Enable CAN1 and CAN2 clock */
97
98
  LPC_PINCON->PINSEL0 &= ~0x0000000F;  /* CAN1 is p0.0 and p0.1  */
99
  LPC_PINCON->PINSEL0 |= 0x00000005;
100
101
  LPC_CAN1->MOD = 1;    /* Reset CAN */
102
  LPC_CAN1->IER = 0;    /* Disable Receive Interrupt */
103
  LPC_CAN1->GSR = 0;    /* Reset error counter when CANxMOD is in reset  */
104
105
  LPC_CAN1->BTR = can_btr;
106
  LPC_CAN1->MOD = 0x0;  /* CAN in normal operation mode */
107
108
  LPC_CAN1->IER = 0x01; /* Enable receive interrupts */
109
  return( TRUE );
110
111
112
113
** Function name:    CAN_SetACCF_Lookup
114
115
116
117
118
119
120
121
void CAN_SetACCF_Lookup( void )
122
123
  uint32_t address = 0;
124
  uint32_t i;
125
  uint32_t ID_high, ID_low;
126
127
  /* Set explicit standard Frame */
128
  LPC_CANAF->SFF_sa = address;
129
  for ( i = 0; i < ACCF_IDEN_NUM; i += 2 )
130
131
  ID_low = (i << 29) | (EXP_STD_ID << 16);
132
  ID_high = ((i+1) << 13) | (EXP_STD_ID << 0);
133
  *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low | ID_high;
134
  address += 4;
135
136
137
  /* Set group standard Frame */
138
  LPC_CANAF->SFF_GRP_sa = address;
139
140
141
  ID_low = (i << 29) | (GRP_STD_ID << 16);
142
  ID_high = ((i+1) << 13) | (GRP_STD_ID << 0);
143
144
  address += 4;
145
146
147
  /* Set explicit extended Frame */
148
  LPC_CANAF->EFF_sa = address;
149
  for ( i = 0; i < ACCF_IDEN_NUM; i++  )
150
151
  ID_low = (i << 29) | (EXP_EXT_ID << 0);
152
  *((volatile uint32_t *)(LPC_CANAF_RAM_BASE + address)) = ID_low;
153
  address += 4;
154
155
156
  /* Set group extended Frame */
157
  LPC_CANAF->EFF_GRP_sa = address;
158
159
160
  ID_low = (i << 29) | (GRP_EXT_ID << 0);
161
162
  address += 4;
163
164
165
  /* Set End of Table */
166
  LPC_CANAF->ENDofTable = address;
167
  return;
168
169
170
171
172
173
** Descriptions:    Set acceptance filter and SRAM associated with
174
175
** parameters:      ACMF mode
176
177
178
179
180
void CAN_SetACCF( uint32_t ACCFMode )
181
182
  switch ( ACCFMode )
183
184
  case ACCF_OFF:
185
    LPC_CANAF->AFMR = ACCFMode;
186
    LPC_CAN1->MOD = LPC_CAN2->MOD = 1;  // Reset CAN
187
    LPC_CAN1->IER = LPC_CAN2->IER = 0;  // Disable Receive Interrupt
188
    LPC_CAN1->GSR = LPC_CAN2->GSR = 0;  // Reset error counter when CANxMOD is in reset
189
  break;
190
191
  case ACCF_BYPASS:
192
193
  break;
194
195
  case ACCF_ON:
196
  case ACCF_FULLCAN:
197
    LPC_CANAF->AFMR = ACCF_OFF;
198
    CAN_SetACCF_Lookup();
199
200
  break;
201
202
  default:
203
  break;
204
205
  return;
206
207
208
209
** Function name:    CAN1_SendMessage
210
211
** Descriptions:    Send message block to CAN1
212
213
** parameters:      pointer to the CAN message
214
** Returned value:    true or false, if message buffer is available,
215
**            message can be sent successfully, return TRUE,
216
**            otherwise, return FALSE.
217
218
219
uint32_t CAN1_SendMessage( CAN_MSG *pTxBuf )
220
221
  uint32_t CANStatus;
222
223
  CANStatus = LPC_CAN1->SR;
224
  if ( CANStatus & 0x00000004 )
225
226
  LPC_CAN1->TFI1 = pTxBuf->Frame & 0xC00F0000;
227
  LPC_CAN1->TID1 = pTxBuf->MsgID;
228
  LPC_CAN1->TDA1 = pTxBuf->DataA;
229
  LPC_CAN1->TDB1 = pTxBuf->DataB;
230
  LPC_CAN1->CMR = 0x21;
231
  return ( TRUE );
232
233
  else if ( CANStatus & 0x00000400 )
234
235
  LPC_CAN1->TFI2 = pTxBuf->Frame & 0xC00F0000;
236
  LPC_CAN1->TID2 = pTxBuf->MsgID;
237
  LPC_CAN1->TDA2 = pTxBuf->DataA;
238
  LPC_CAN1->TDB2 = pTxBuf->DataB;
239
  LPC_CAN1->CMR = 0x41;
240
  return ( TRUE );
241
242
  else if ( CANStatus & 0x00040000 )
243
244
  LPC_CAN1->TFI3 = pTxBuf->Frame & 0xC00F0000;
245
  LPC_CAN1->TID3 = pTxBuf->MsgID;
246
  LPC_CAN1->TDA3 = pTxBuf->DataA;
247
  LPC_CAN1->TDB3 = pTxBuf->DataB;
248
  LPC_CAN1->CMR = 0x81;
249
  return ( TRUE );
250
251
  return ( FALSE );
252
253
254
255
**                            End Of File
256
