Forum: FPGA, VHDL & Verilog verilog - print to file a 3d array
Author: Uzi Co (Company: uzico Inc.) (uzicohen10)
How do i export to file a 3d array in verilog?
usually i use writememh with  2d arrays
example:
   Declaration:
   reg [7:0] arr [31:0];
   write to file:
   $writememh("PrintedArr.txt",arr);
Tnx in advance.
Author: Marcus Harnisch (mharnisch)
> example:
>    Declaration:
>    write to file:
Strictly speaking this is a 1d array of vectors (aka memory). And just
to be a PITA, I would like to remind you that $writememh is not part of
IEEE-1364 2005. So either you are using a vendor extension or IEEE-1800
2005 (SystemVerilog).
The point of $writememh is to store data in a way that can be read back
using $readmemh. Since the latter can fill only memories (1d arrays),
what would you expect as output of $writememh? In any case you could
just use write your own function and use $sformat or $psprintf (which is
also non-standard, but widely supported).
Hope this helps
Marcus
http://www.doulos.com/knowhow/verilog_designers_guide/
  • [vhdl]VHDL code[/vhdl]
