Forum: ARM programming with GCC/GNU tools EP93xx FREE-RTOS and VIC interrupts
von Thomas M. (thames)
Anybody know of a freeRTOS implementation for the Cirrus EP93xx chip?
I am trying to keep the basic set of interrupt functions used in the
original ARM port used for other devices.
This requires a direct vectored jump to a program memory location held
in the VIC address register when an IRQ arives. In many ARMs this is
simply done by including a "ldr pc,[PC,#-0xFF0]" in the IRQ entry of the
vector interrupt table (at RAM zero). But for some reason the EP93xx
doesn't seem to implement this, at least it doesn't work here :-(
Is there a way around it? (without modifying the RTOS code) i.e. how can
I implement a jump to the contents of the VIC1 vector register (at
0x800B0030) without using any other CPU registers, or saving anything on
the stack?
