Forum: ARM programming with GCC/GNU tools Accessing Eclipse build variables in a Makefile
von Bernard M. (bernard_m)
Hi All,
I am using eclipse and have a Makefile project. (It builds fine ..)
I would like to access the Eclipse variable that shows what the current
configuration is (i.e Release, Debug etc), so that I can change the
optimization flags in my Makefile...
i.e in my Makefile I want to do:
ifdef (Release,$VariableName)
 some stuff ..
else
ifdef (Debug, $VariableName)
 some other stuff
endif
I need to know what the variable name is ..
Thanks,
Bernie
I have never tested this myself: it's possible to read environment
variables from make and Eclipse offers the option to set environment
variables. Maybe you can also use special make targets in Eclipse and
include additional target-rules for them.
Yes, I could specify special make targets, but that's really not what I
want to do ..
I just need to know how to access the variables in eclipse. You say you
havn't tested this, but do you know how to access these variables in
make?
thanks,
B
EDIT: I notice in eclipse that the enviroment variable that holds the
current build configuraion is called "ConfigName", however accessing
that name with the syntax "ifdef (Release,$Configname)" in the makefile,
does not seem to work.
I found out how to fix this ..
Under Eclipse properties for the project goto C/C++ Build->Environment
and add the system variable ConfigName so that it is exported .... it is
then visible to the make program ... works great.
von abc (Guest)
Hi..
Please help..In eclipse..
if the code is :
#ifdef ABC
code();
#endif
I want to access the function code() using Open Declaration. How can I
do this without defining ABC in source code..
Thanks in advance..
von Jax (Guest)
Simple.
Project/Properties/C/c++ General/Paths and Symbols/Symbols
then "Add".
In most cases you want to tick "Add to all configurations"
and possibly also "Add to all languages"
Else RTFM.
Jax
von HausaSaxSnila (Guest)
Willkommen in unseren Sexchat.
 Der Sexchat gibt dir eine Alternative transvestiten kontakte  und
natürlich vieles mehr,unter anderem erotische Rollenspiele
 Hier in unsrem Sexchat erwarten dich transvestiten kontakte  Flirt und
Sextalk
 Eventuel suchst du Aufregend chatten , sicher bist du hier genau
richtig.Ok,worauf wartest du?
 sexuelle Vorlieben nackt sexy kostenlos  ,sofort anmelden .
 Du suchst jemand von Graz, oder von München, vieleicht aus Regensdorf ,
vieleicht von Wallisellen, vieleicht in AffolternamAlbis? Bestimmt ist
da jemand dabei.!
