Forum: µC & Digital Electronics LPC1768 does not wakeup from deepsleep
von Sven (Guest)
Hey,
I am useing some examples from Keil and I am working with the LPC1768.
I am trying to put the controller into deepsleep or power down ect. pp.
My problem is, that the controller does not wake up from deep sleep and
power down mode.
In the Attachment you can find my Code, it would be great if you can
help me.
thanks =)
: Moved by Admin
von Sven (Guest)
so here in an easier way, but the problem is the same the µC does not
wakeup from deepsleep, powerdown or deep power down.
#include "lpc17xx.h"
#include "type.h"
#include "extint.h"
void main(void)
/***********PINs einstellen**********/
/*************LEDs******************/
  LPC_GPIO2 -> FIODIR |= 0xFF;    // P2[0..7] Ausgänge
  LPC_GPIO2 -> FIOCLR |= 0xFF;    // alle Pins ausschalten
/************Taster****************/
  LPC_GPIO3 -> FIODIR &= (1<<25);   // P3[25] Eingang
/************Interrupt*************/
LPC_PINCON->PINSEL4 &= ~(0x03<<20);   // Reset des Pins
LPC_PINCON->PINSEL4 |=  (0x01<<20);  // Config P2.10 = EINT0
LPC_GPIOINT->IO2IntEnF = 0x200;    // Port2.10 is falling edge.
LPC_SC->EXTMODE = EINT0_EDGE;    // INT0 edge trigger
LPC_SC->EXTPOLAR = 0;      // INT0 is falling edge by default
NVIC_EnableIRQ(EINT0_IRQn);       // Enable IRQ for EINT0
  while(1)
30
    if (!(LPC_GPIO3 -> FIOPIN & (1<<25)))
31
32
      LPC_GPIO2 -> FIOPIN = 0xFF;
33
      SCB -> SCR = 0x04;
34
      __WFI();
35
36
37
38
39
40
41
void EINT0_IRQHandler (void)
42
43
  LPC_SC->EXTINT = EINT0;  //clear interrupt
44
  LPC_GPIO2 -> FIOCLR = 0xFF;
45
von Sven (Guest)
nobody?
von Lutz (Guest)
Reset value of this register is 0x0. Your code doesn't change anything
in this case, but take care if the value of FIODIR differs from 0x0.
You've probably forgotten the '~'.
Unneccessary, because the reset value of PINSEL4[21:20] is 00. And this
value is also overwritten with
but that's not a problem; you can make it sure or obvious by this way.
0x200 codes a falling edge interrupt enable for P2.9, not for P2.10.
Take care of the bitposition when bitshifting or when making an absolut
assignment. This seems to be the problem and my "analysis" stops at this
line of code.
von Lutz (Guest)
P.S.: When you change your language to German your name is Jannik?
Strange ...
