Forum: µC & Digital Electronics Problem Interfacing ADC AD7856 with LPC2148
Author: Joydeep S. (joydeep_s)
Hello
I am trying to interface external ADC AD7856 with LPC2148. Here goes my
code
int main(void)
  U16 adc_val = 0;
  U8 data = 0;
  U8 upper = 0, lower = 0;
  HardwareInit();     //SPI and ADC initialised
  AD_7856_SYNC_SET(); // SYNC bit set high
  while(1)
   while((AD_7856_BUSY_IOPIN & AD_7856_BUSY));//wait for BUSY bit to set 0
    AD_7856_SYNC_CLR();         // SYNC bit high
    delay(3);
    data = 0xE0;                //Upper MSB write
    SPI_Write(1, &data);
    data = 0xC0;                //lower LSB write
    delay(3);
    AD_7856_SYNC_SET();
    delay(3);
   AD_7856_SYNC_CLR();
   delay(3);
   SPI_Read(&upper);          //Upper MSB read
   adc_val = upper <<8;
   SPI_Read(&lower);          //Lower LSB read
    adc_val = adc_val | lower;
    AD_7856_SYNC_SET();
  return 1;
According to the data I can writing I should read back the data as
0x20C0 but instead the output is always Garbage values.
Moreover the Busy  bit never sets high during conversion it always
remains low.
Any suggestion is most welcome. And any change in the code required???
Joydeep
