I need to implement a strobe-signal-delay of 2ns in the output-path to get the optimal point in time for clocking an external chip over a delayed data-path. (FPGA: LatticexP2-family, there are no DLLs and a have no PLL anymore) Implementation as synchronous-logic would lead to clk-freuqency of 500MHz... Is it possible to work around by instantiatig dedicated synthesis-library entities to utilise the delay, ore/and making some constraints.... ?
There are always two ways to adjust small delays. 1. Adding logic or delay elements either in rtl description (make sure that synthesis do not optimize away) or by instantiation of library cells from your FPGA. Some FPGA technologies has dedicated delay elements. 2. Routing. Move logic elements in the path in a way that the routing length increase. That need much trial and error, because you have usally no real influence to the routing. 2a. Routing add I/O. do not use the FF in the I/O cell and you will get additional delay. Be aware, you have to check the timing at least at best and worst case condition.
