Well guys...Ive been trying to find a solution for this thing quite few days but could not reach anything till now! Im simply trying to implement a very small system (muliplierbsb--in attachmenet) to send and receive data through the microblaze to my core(Muliplier_VHDL. I created a core(user_logic) in XPS with 3 slave registers. Inside this core I used a multiplier core(Muliplier_VHDL) which I designed. My aim is to write to the slave registers from the microblaze and then read the values in the registers by Muliplier_VHDL core and the write back to a register to be able to read the value written to this register from the microblaze again. After implementing this and trying to download the bit stream I had the following errors ERROR:NgdBuild:455 - logical net 'clk_100_0000MHz' has multiple driver(s): pin PAD on block lmb_bram/lmb_bram/clk_100_0000MHz with type PAD, pin CLKOUT0 on block clock_generator_0/clock_generator_0/Using_PLL0.PLL0_INST/PLL_INST/Using_ PLL_A DV.PLL_ADV_inst with type PLL_ADV ERROR:NgdBuild:924 - input pad net 'clk_100_0000MHz' is driving non-buffer primitives: pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Byte_Enable_0 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Byte_Enable_1 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Byte_Enable_2 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Byte_Enable_3 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_0 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_1 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flo w_I/Byte_Doublet_Handle_I/MEM_D ataBus_Write_Data_2 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_3 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_4 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_5 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_6 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_7 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_8 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_9 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_10 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_11 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_12 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_13 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_14 with type FDRE, pin C on block microblaze_0/microblaze_0/Performance.Data_Flow_I/Byte_Doublet_Handle_I/ MEM_D ataBus_Write_Data_15 with type FDRE ERROR:NgdBuild:809 - output pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/Out_1_s<0>' has an illegal load: pin I4 on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/IP2Bus_Data<29>1 with type LUT6 ERROR:NgdBuild:809 - output pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/Out_1_s<1>' has an illegal load: pin I4 on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/IP2Bus_Data<30>1 with type LUT6 ERROR:NgdBuild:809 - output pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/Out_1_s<2>' has an illegal load: pin I4 on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/IP2Bus_Data<31>1 with type LUT6 ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<2>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_2 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<2> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<2>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_2 with type LD ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<1>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_1 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<1> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<1>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_1 with type LD ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<0>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_0 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<0> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s<0>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_1_s_0 with type LD ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<2>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_2 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<2> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<2>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_2 with type LD ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<1>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_1 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<1> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<1>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_1 with type LD ERROR:NgdBuild:455 - logical net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<0>' has multiple driver(s): pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_0 with type LD, pin PAD on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<0> with type PAD ERROR:NgdBuild:924 - input pad net 'muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s<0>' is driving non-buffer primitives: pin Q on block muliplierbsb_0/muliplierbsb_0/USER_LOGIC_I/In_2_s_0 with type LD ------------------------------------------------------------------------ --- when I synthesize and implement the design in ISE it does not give any errors, errors only appear when trying to download the bitstream in XPS I do Understand that there is something wrong with the clock and that it has multiple drivers, but how can I find this and how can I fix it. Is it something in the pin assignment? Also concerning the other signals, I totally have no idea whats going wrong. Its my first time to try to integrate a whole system together and communicate with the microblaze, any advice concerning this will be appreciated. Thanks, Eshbon
