Forum: FPGA, VHDL & Verilog help in image processing using verilog
von Alangs K. (Company: Kenit) (alangs)
Hi FPGA experts i need a help in processing an image.....plz find the
attachment of the image it is having white and black lines...here i have
to count those white lines only exactly(17)....in which algorithm i can
process it.....already i processed the image using sobel edge detection
using verilog but i didnt get exact edge detected image...so that i cant
able to proceed furthur....so some one plz guide me in which way i can
implenment this in FPGA....
: Locked by Moderator
von Andreas S. (andreas) (Admin)
It's easy to develop an algorithm that returns "17" for this picture;
the easiest would be one that returns a constant. If you want to develop
something that returns the number of lines for other pictures as well,
first you need to look at more samples or have some other information
about how these pictures will look: are the lines always straight and
exactly horizontal? Does the number of lines vary between 15 and 20, or
between 1 and 100? And so on.
Just an idea:
1. average over a few values in x direction (or over the whole length)
to get a 1-dimensional vector
2. subtract the mean value
(2.5. apply median filter if necessary)
3. count the number of zero crossings
von na sowas (Guest)
This isn't a particular problem for an FPGA expert, but one for a signal
processing guy. Try to ask them for a solution for your problem.
http://embdev.net/forum/digital-signal-processing
And when you have a working algorithm you can step back to the FPGA
part.
von namita (Guest)
my project is image processing using fpga. m go to use altera DE-2 kit
for it. plz tell me wether it is convineint or not. how can we read an
image from pc, send the vhdl code also....plzzzz help....
von praveen (Guest)
hello,
am praveen vanaparthy studying mtech 2nd year.
now am doing my project on image enhancement using fpga, for this i want
to use vertex-2-pro kit.
 how can we read an image from pc/memory card, send the verilog code
am created .txt file using matlab, but i didnt get how to write code in
verilog using this .txt file.
and my doubt is about interfacing part( ie how to interface fpga with
display, memory device).
please help me
von P. K. (pek)
...and divide by 2, as you'll get two crossings per thread.
This approach can be a starting point, if your picture(s) look always
the same (i.e the threads are always in horizontal direction.
However, the approach needs to be more sophisticated, if you intend to
make out missing threads, snapping threads or similar.
Some exception handling may be necessary, if thread(s) at top and bottom
are not completely within the picture.
von SONALI B S (Guest)
Hi FPGA experts!!!!
Im doing a validation of my project "Multiprecision floating point unit
using a dsp application".I wanted ur help in what image processing i can
do which involves floating point in it.I found out on net that image
inversion can be done but im unable to take the txt file converted into
floating point format.So plz help me.
SONALI B S wrote:
> So plz help me.
Start an NEW thread for a NEW question, please.
Add as much information as possible. Post that text file or a part of
it. Tell, what your actual problem is with that text file. Tell what HDL
and toolchain you use. With the information you told up to now no one
will able to help you in any way.
: Edited by Moderator
This topic is locked and can not be replied to.
