Forum: ARM programming with GCC/GNU tools Arm Flash programming, OpenOCD, GDB ?
Author: gahelton (Guest)
I have some questions concerning programming the flash (for the purposes
of debugging) for ARM microcontrollers. First, I am completely new, so
please be gentle. I've spend quite a bit of time researching, but in
many cases, more questions arise than answers.
My setup is as follows:
Eclipse Helios edition
Olimex ARM-USB-TINY debugger
Olimex LPC2103 eval board
Yagarto (GCC Build 4.5.1) I think
OpenOCD R204
GDB 7.1
The Olimex install CD was used to get a basic setup, but a new Yagarto
install was performed to get the latest GCC build. Likewise an update of
Eclipse was performed. Test software compiles fine.
Now comes debugging. Generally, I would like to debug in flash, so I
need to upload the program into flash and execute. I've looked at the
configuration files (*.cfg) that came on the Olimex CD, and many, many
others from lots of sources. Problem is, there seems to be lots of ways
to accomplish this (too many in fact).
First, there doesn't seem to be any commands in the config files from
Olimex that programs flash. Looking through various websites and forums,
there seems to be methods for letting GDB perform the flash programming,
or OpenOCD.
For GDB, some commands in the config file for allowing GDB flash
programming appear to be (partial):
Code:
#daemon configuration
telnet_port 4444
gdb_port 3333
#setup gdb to program flash
gdb_memory_map enable
gdb_flash_program enable
gdb_breakpoint_override hard
But there also seems be be a "source" GDB command that needs to be added
somewhere in here as well. It looks like the "source" command calls
another script file. Are the actual flash programming commands in this
seperate script file ? Are these just OpenOCD "flash write_image"
commands or what ? I've never seen the contents of this second script
file.
There also appears to be a way to add the flash programming commands
within the configuration file. If the "init" command is added after the
configuration, then the flash programming commands (OpenOCD type
commands like "flash write_image") could follow the init command to
program flash. I say "appears" because I've never actually seen a
complete config file like this.
Could someone please describe some of the flash programming/debugging
options. I'm not interested in 1000 different ways of doing the same
task - just a few good ones.
Thanks
Author: mksuth (Guest)
I have the exact same question. Did you ever make any progress with
this?
gahelton wrote:
(also in reply to the previous message)
> OpenOCD R204
> GDB 7.1
I'm also using the gdb-hardware-debugging plugin. Depending on the
version of Eclipse an additional file has to be downloaded - I have seen
this issue with Helios (Eclipse bug 326176). Another option might be the
Zylin plugin which offers similar functions (I have not used it so far
so can not comment on it).
Maybe Eclipse ganymede couly be used for tests first to avoid possible
problems with helios.
There are some config files bundled with OpenOCD ("target-library").
Usually from inside Eclipse there is not need for special commands to
write the internal flash. In the OpenOCD config-files just the
"flash-bank" has to be defined. See the configuration files that come
with OpenOCD. gdb's load command can be used to program the flash-memory
since OpenOCD supports gdb's vflash interface. The is a checkbox "load"
in the configuration dialogs of the hardware-debugging plugin.
> or OpenOCD.
> Code:
> telnet_port 4444
> gdb_port 3333
these should be default.
I did not need this option.
Please read the OpenOCD-manual. There is a section about OpenOCD and
gdb.
The source command "tells" gdb path and name of the elf file. There is a
field in the gdb hardware-debugging plugin dialogs to set the binary
file. This should work with the "load-checkbox" but for gdb's
"verify_sections" the source-command was also needed during my tests
with Helios. I have made an entry in the Eclipse bugzilla (#332470) for
this but so far no reaction.
> file.
write_image is useful for stand-alone programming without gdb. But
should not be needed with gdb.
As far as I know init is needed anyway to leave the "init-sequence" and
enter "command mode".
- install gdb-hardware debugging plugin
- create debug configuration for the plugin
- select binary in dialog (elf-file)
- check at least reset and load boxed in the dialog
- launch debug configuration
