Forum: ARM programming with GCC/GNU tools Undefined reference error (yagarto/msys/gcc)
Author: superbird70 (Guest)
Hi!  I have been trying to compile a file, but I keep getting error
messages similar to the one below, complaining about undefined
references to things like _read, _close, _lseek, etc...
How do I fix this?
C:\msys\1.0\home\yagarto\newlib-build\arm-none-eabi\newlib\libc\reent/..
/../../../../newlib-1.18.0//newlib/libc/reent/lseekr.c:58:  undefined
reference to '_lseek'
superbird70 wrote:
>...complaining about undefined
FAQ. Read the newlib's manual
(ftp://sources.redhat.com/pub/newlib/libc.pdf), section System Calls,
check source-files called syscalls.c (or similar) for examples from
Yagarto or other sources.
Author: Kenan Özdemir (gladio)
Did you already solved it?
I think those functions are not provided so what you have to do is to
implement it. I had the same errors. I will attach my file which you can
use.
Author: Hans Mueller (hereiam)
I trid to use you file but I get some errors.
Every from you as avoid warning marked line I get error messages.
For example:
Assiment to itself file = file
I use C not C++. Could this be a reason and how can I fix this in C?
