Forum: ARM programming with GCC/GNU tools compiler for arm + linker problems
von Cloud S. (goblin12)
Hi community,
right now i am using eclipse + winarm
and want to compile some c code for my
AT91SAM9RL board (ARM based)
for compiler
arm-elf-gcc
and linker got some problems
when i use
arm-elf-gcc, g++
i get undefined reference errors
when i use
arm-elf-ld
it works but i get .exe as result
i need .elf , .hex or .bin
can someone help?
: Moved by Moderator
Cloud Strife wrote:
> Hi community,
> for compiler
> arm-elf-gcc
You might want to update to a more up-to-date GNU tool-packate (WinARM
ist rather old now). See yagarto.de or search for Codesourcery CS G++
lite for arm-eabi.
> when i use
> arm-elf-gcc, g++
Not enough information, at least show the error messages.
> when i use
> arm-elf-ld
Avoid calling -ld directly for linking.
Martin Thomas wrote:
> Cloud Strife wrote:
>> Hi community,
>> for compiler
>> arm-elf-gcc
> lite for arm-eabi.
>> when i use
>> arm-elf-gcc, g++
error message:
undefined reference to _read_r , ..._lseek_r ,...i_satty_r etc
i am using yagarto gcc as compiler now
>> when i use
>> arm-elf-ld
idk what files the AT91SAM9RL can understand but i guess i need .elf or
.bin
