Forum: Analog Circuits L298 exploding, after having worked perfectly
von Dave (Guest)
Hi everybody
I built myself a CNC-mill (3-axis) and my "own" controller circuit. I'm
using the well-know L297 L298 chip combination, more or less identic
with the manufacterer datasheet.
After some trouble in the beginning the 3 controller boards were working
perfectly. But then I decided to put the boards into a new case. After
that the L298s exploded.
Before they did so, the motor was "stuttering" around and it only
happended when using more than one board at the same time (over enable)
After burning some (3) L298 I decided to take a closer look at the
circuits. Maybe I had damaged some circuit paths. But there was nothing
obvious to see. And I checked the pcbs for hours but I couldn't find
anything.
What are the most probable reasons for burning the L298? (sense,
clock???)
PS: I know this is quite a imprecise question/information but I hope you
can help me somehow. I can post the circuit (.eagle file) if necessary
but the circuit should be ok (it worked fine for a few months).
Thank you in advance for your help
Dave
von Floh (Guest)
> clock???)
Your diodes are ok? A missing diode kills a L298 with ease.
L298 mounted on Heatspreader?
Same Supply after changing case?
von Dave (Guest)
Yes, the L298s are mounted on heatspreader, supply is the same as
before. I checked the diodes with a multimeter. They were permeable from
one side and blocked from the other. Seem to be normal, but maybe I
remove them and check them individually.
Thank you
Dave
von C. H. (_ch_)
Dave schrieb:
>...it only happended when using more than one board at the same time...
>...Yes, the L298s are mounted on heatspreader, ...
Are they isolated against the heat think?
Christian
von Dave (Guest)
Yes, they are isolated. I mounted a seperate heatsink on every L298.
There is no connection.
Thanks for the tipp
von Lehrmann M. (ubimbo)
well I had these problems after having voltage reverse. Afterwards it
worked perfectly a few seconds then it started expolding / melting.
von Anselm 6. (anselm68)
Are the heatsink´s are mounted at the case of your new housing?
von Dave (Guest)
Well, I think I have to reassemble the boards and make sure everything
works fine again?? Maybe it's a wrong connected voltageconnection or a
problem with the diodes.
The heatsinks are not connected and not mounted in the case. They are
freestanding in the case.
Thanks for all your support, guys. I'm gonna test it again (and burn
more L298?? ;-) ).
I can't see the problem right now, let's hope it will work again. From
the outside everything seems to be ok!
Dave
von Raimund R. (corvuscorax)
Since you moved the working hardware just in a new case I could guess
that something with grounding/earthing is imperfect now. Maybe some GND
potentials are now floating which could cause excessive high voltages on
certain channels - at least this might match with your observation that
a separate channel does work, but not all together.
Might be worth to look for such an issue.
von schodavi (Guest)
Thank you for your guesses and help
I reassembled the boards and the cables/connections, and that time I
checked everything more than twice (make sure that there is no unwanted
connecion). I think too that there was a problem somehow with ground or
just something badly connected.
I was really scared to test them again because when they explode it is
quite load (I use a 24V/10A power supply)
but finally I did it the controllers are working perfectly again. ;-)
Thanks for all
The next time I am more carefull when changing the case.
Dave
von Philipp B. (philipp_burch)
> Dave
And please be more careful when attaching your power supply. You sure
have a supply with some kind of current limit, don't you? Otherwise it's
quite likely, that you kill something if there is a mistake somewhere...
The power supply is an industrial supply (TRACO). It has a fuse for 10A.
On the controller boards I have fuses too : 5A
I don't have the right fuses at home right now, but I will buy some 3A
fuses soon.
Do you think it's better to switsch on the L298s over enable input
instead of directly plugging in the power supply(enable always on high)?
Thanks
> fuses soon.
That won't make a big difference.
The problem is not the fusing in normal operation. But you really
should test your circuits using a current-limited supply after doing
some modifications if it is possible. I guess you have seen the reason
for this in a quite impressive form ;)
Well, that may be a good idea. So you can disable the whole power part
if something is wrong. An example for this could be insufficient voltage
for the controller (brown-out).
von g457 (Guest)
schodavi schrub:
Datasheet [1] suggests (page 7/application information):
Turn-On and Turn-Off : Before to Turn-ON the Sup-
ply Voltage and before to Turn it OFF, the Enable in-
put must be driven to the Low state.
I guess weird things can happen if you don't. Like escaping magic smoke
HTH
[1]
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-5/DSA-95442.html
von Dave (Guest)
g457 schrieb:
> Datasheet [1] suggests (page 7/application information):Turn-On and Turn-Off :
You are right, but before/during the explosions, I was always switching
on and off the L298 via enable input. Just today after the reassemble I
forgot it and directly switched on the power supply. But it didn't cause
any damage at all.
This is probably a safety feature for people who are using simpler power
supply (which can have a voltage top when switching on/off (induction).
Mine was really expensive (but I got it for free from a friend ;-)
PS: I have a current-limited power supply but the problem is that it
isn't really powerful.  Maybe I have to buy an additional (better) one??
PS: There was a lot of noise from the choppers during operation, so I
replaced some GND - wires with thicker ones. Now the noise is much lower
(but still there of course). I think it was a problem with GND
connection or supply voltage wrongly connected. Finally it is working
now. I also added a mechanical switch to manually control the enable
inputs.
That's it. Now I can do some milling again ;-)!
von Dave (Guest)
Thanks for the great support and all your help.
