Forum: ARM programming with GCC/GNU tools no memory region specified for loadable section - error
Author: Muthukrishnan Neelakandan (Company: Aperto Networks) (krishdsp)
Hi everyone,
I have got a Olimex SAM7s256 ARM board. I am new to the field of
embedded programming. I am using Ubuntu 10.04. I installed GCC 4.2.2 and
GNU assembler, linker and obj copy all 2.18 versions.
For writing in the board's RAM (ARM's ram) I used a custom made SAM-
Boot utility called Sam_I_Am from the following website
http://claymore.engineer.gvsu.edu/~steriana/Software/
It is a command line program and I was able to connect to the board.
Now I downloaded a LED blinking program and tried to compile and run to
get the HEX file to dump in the board.
When I run the 'make' I get the following error,
 error: no memory region specified for loadable section `.text.1'
make: *** [blink.elf] Error 1
Can anyone help me in that? I am not able to understand this. In some
other forums it is given that it is a bug w.r.t GCC 4.2.2. When tried to
search for  'text.1' it is shown in many discussions that the linker
will break the .text into .text.1 and .text.2 if it is more than 50K in
size. Is it the case here?
I am really new to this and it is one of knowing whether my board in
conjunction with the boot loader and linux works after I purchased it.
Any suggestion here will be very much appreciated.
I am attaching both the make file and the linker file for clarification.
The linker-script looks too simple. There are no input-sections (.text)
given in in the defintion for the .text output-section. Get Atmel's
software-package for the AT91SAM7S-EK, as far as I remember the packages
includes linker-scrips, makefiles, startup-code for both "targets" FLASH
and RAM.
The same error got solved when I downgraded GCC to 4.1.1 and bin-utils
to 2.17.
I was told by come other person that it is due to the problem with GCC
4.2.2. Is it so? If so then is there a fix to this problem?
Thank you.
Muthukrishnan Neelakandan wrote:
> Hi,
> to 2.17.
> 4.2.2. Is it so?
Maybe the older versions of the toolchains just had some build-in
defaults to handle the .text/.data/.bss input-sections during linkage. I
have never seen a linker-script that has been reduced like the one given
in the attachment.
Try to place the input-section names for .text/.data/.bss in the
defintions for the output-sections in the linker-script. You may use the
linker-scripts from Atmel's software-package or the default
linker-script (arm-*-ld --verbose) as template.
webmaster@embdev.netContactAdvertising on EmbDev.net
