Forum: ARM programming with GCC/GNU tools How to use USBRAM for general purpose?
von Prakash R. (Company: Coinel Technology Solutions) (prakash)
According to LPC17xx user manual the LPC1768 has a total of 64kB of
SRAM. I understand that there is a 32kB bank of SRAM connected to the
CPU's instruction and data busses, which is readily accessible.
There are two more 16kB banks of SRAM which are stated as typically
being used for peripheral data but can supposedly still be used for
general purpose instruction and data storage.
In my project I have to use 40kb to 45kb SRAM. Could you please anybody
tell me how to use USBRAM? If any body can help on this, that will be
very appreciated.
-Prakash
9886545216
Fist of all make sure if the two additional regions can be freely used
by the core. There may be limitations to use this RAM.
> very appreciated.
a possibility:
- define the memory-region of the USB-RAM in the linker-script
(additional line in the MEMORY block)
- use the section variable attribute (see GCC manual) to assign the
variables which should be stored in the USB-RAM
- define additional output-section which places the input-sections given
with the attribute into the USB-RAM.
- you may have to copy initial values and/or write zero-values for the
variables in the addtional section.
You may look into startup-codes, linker-scripts and examples for GBA.
