Attached files:Hello, I have an AT91SAM3U-EK and the SAM-ICE JTAG programmer. I am using YAGARTO along with the sample project I have attached. This is the tutorial I am following http://yagarto.de/howto/jlink/index.html I am slightly confused about the programming procedure and how it works. This is the GDB script that is included with the example project
# # This config file was tested with J-Link GDB Server v4.10i # # connect to the J-Link gdb server target remote localhost:2331 # Set gdb server to little endian monitor endian little # Set JTAG speed to 5 kHz monitor speed 5 # Reset the target monitor reset monitor sleep 100 # Set JTAG speed in khz monitor speed auto # Vector table placed in RAM monitor writeu32 0xE000ED08 = 0x20000000 load monitor reg r13 = (0x20000000) monitor reg pc = (0x20000004) break ResetException break main continue |
Rather than asking "what does this do" I would like to know where I need to look to figure it out my self. I had to install the J-Link server software along with all of the YAGARTO tools so I am not sure what exactly is going on when I follow the directions, or what tools are being used to do the programming, so I am not sure what documentation I need to dig into. If anyone can tell me exactly what is going on here, or point me to some good resources I would really appreciate it. I want to be able to write my own GDB scripts and extend these techniques as much as possible.
