Forum: ARM programming with GCC/GNU tools ARM: Using IAR for Linux development
Author: Thomas Messum (thames)
Is there a description somewhere on the net on how to use/modify the IAR
IDE to generate linux executable files?
In plain english please as I am only a level zero linux novice!
This is specific to the ARM9 TS7200 board
I shall try the TS7200 forum as well, but I understand there is a lot of
expertise in here, so might as well ask!!
Thanks
Tom
>I shall try the TS7200 forum as well[...}
It might be easier to send an e-mail to the IAR-support. Although this
forum as a rather general most of the readers/writers here use the GNU
toolchain.
From the few things I have done with Linux on embedded targets I can
just recomment to use a Linux-system (maybe in virtual hardwware) to
host the building system.
Yes thanks I should try along those lines.
In practice, would this adaptation amount to little more than including
the right precompiled object files, a new startup asm, and maybe a few
other files in the project? or am I missing something?
I know the IAR compiler can generate the right linux-compatible format
binaries. But I can't understand why IAR haven't provided facilities for
generating Linux from the start. Are there any licensing or patent
issues as well?
thanks
Tom
webmaster@embdev.netContactAdvertising on EmbDev.net
