Forum: ARM programming with GCC/GNU tools need help with debugging Cortex M3 (STM32) using Eclipse, YAGARTO and J-Link
Author: jera (Guest)
I'm trying to set up a development environmet for ARM Cortex M3
(STM32F107) on windows XP. I'm using Eclipse (with Zylin plugin),
YAGARTO, gdb and J-Link debugging hw. All of these are new to me and I'm
bit confused with all the script and config files.
Getting freeRTOS to work is the target and I found an example project
close to my setup from here:
http://developers.stf12.net/just-another-eclipse-demo-str91x To start
with I modifyed it to be only a led blinker without rtos and can compile
it. I have currently the STM32CMICOS-EVAL board
(http://www.st.com/stonline/products/literature/um/16173.pdf) with
J-Link On Board chip and later possible some other board as well. J-Link
gdb server is recognizing the target.
As mentioned, I can compile but the above example uses different jtag hw
so flashing and debugging still needs some work and here are my
questions.
1. Which script and config files (and makefile settings) are controlling
flashing and debugging?
2. Is there tutorials/examples for the files?
3. Can I break something with wrong config files?
I'm already followed applicable parts of the following tutorials:
http://developers.stf12.net/eclipse-demo
http://embeddedcraft.org/freearmtools2.html
http://www.yagarto.de/howto.html
jera
Eclise uses the Zylin Plugin to talk to a gdb-server via the gdb-client
(arm-*-gdb). In your case it's the gdb-server from Segger. Did you
configure TCP/IP port correctly (2331 for J-Link gdb-server IRC)?
For flashing the makefile might include calls to an external
flash-programming software but this is not realy needed for debugging.
Just an elf-file is needed.
If you can call a programming-software from Segger from the command line
you can add this call to the makefile, in example in a programm target.
But this is not related to debugging or Eclipse.
I don't know if the J-Link gbd-server has a flash-programming interface.
If yes, the gdb-command load can be used for flashing. There is no need
for a special file.
I don't think so.
You are using the J-Link gdb-server instead of OpenOCD, but the basic
concept is the same as shown in this tutorial.
This is not too helpful since Insight is used as debugging frontend, not
the debugger in Eclipse.
You may want to re-read http://www.yagarto.de/howto/yagarto2/index.html
Sorry, no real "fist hand" recommendations, maybe someone else can write
a little bit more on this. I'm using another hardware-interface
(FTDI2232-based), another gdb-server (OpenOCD) and another plugin
("official" Eclipse/CDT gdb-hardware-debugging plugin).
You may also ask in Segger's support-forum or write an e-mail to the
address mentioned in the imprint or yagarto.de
Thank you for your answer. I managed to get it sort of working, program
is downloaded to flash and debugging is partially working. When single
stepping over for loop (used as delay) program runs away i.e. cursor
never comes back and target must be hardware reseted. Here are my gdb
initialization commands.
target extended-remote localhost:2331
monitor endian little
monitor reset
monitor sleep 500
monitor speed auto
set remote memory-write-packet-size 1024
set remote memory-write-packet-size fixed
monitor flash device = STM32F107VC
monitor flash download = 1
load RTOSDemo.axf
monitor reset
break main
continue
Does that look like reasonable?
How it is selected is the debugging performed from flash or RAM?
In some gdb initialization examples there were commands for setting PLL.
Is that needed? What clock frequency is selected without any commands?
jera
The monitor commands are J-Link gdb-server specific. List looks
reasonable to me but as written, I'm using another gdb-server. Someone
else needs to comment on this.
You already have "from Flash". For "from RAM" Link the application into
addresses in the RAM's address-range (linker-script/setup)
At debugger-startup:
- set the Stack-pointer to first value in vector-table
- set PC to second value in vector-table-table
- make sure the NVIC-offset position is set to the start-address in RAM
early (before an interrupt can occur).
The steps can be implemented as additional commands in you
initialization list.
> Is that needed?
Some targets start at a very slow coreclock (in example 32kHz). So the
PLL gets initializes very early the achieve reasonable
communication/transfer speeds.
Depends on target. Some targets offer external pins of non-volatile
memory-sections to set this up. In your case: If /SRST is asserted and
deasserted during "monitor reset" the clock will be the default clock
after reset as mentioned see STM32 reference-guide.
Apparently OpenOCD supports also J-Link and I may use that as well. How
would you write similar (flash download and debug) initialization
commands for OpenOCD?
jera
P.S. For J-Link GDB server there shuld be "remote" instead of
"extended-remote".
Author: zyklopen (Guest)
I have recently tried OpenOCD for flash operations on STM32F101 ICs and
I can confirm that it works (for the features I tried). I used a current
snapshot from the 0.5.0-dev branch, tagged
91305bfa7f550c96b967008c1512864cffdaa52a, of the github, in conjunction
with the new libusb-win32 V1.2.1.0.
I compiled and ran OpenOCD with the current version of Cygwin (1.7.5) on
XP.
My JLink firmware is V6.
In the past, I used to try OpenOCD/JLink/STM32/XP with several releases
and RCs, but to no avail -- the OpenOCD console was flooded with errors.
GDB I have not tried yet, neither more sophisticated features.
Regards,
zyklopen
webmaster@embdev.netContactAdvertising on EmbDev.net
