Forum: FPGA, VHDL & Verilog VHDL simulation problem-need experts review
Author: Shahul Akthar (Company: pantech solution) (shahulakthar)
i am doing vhdl code for eeprom for write operation.
in that i try to simulate my coding i met with few problems.
i use 2 process statement.
1st process depends on clk input.
2nd process depends on cyc.
In the 2nd process it should consider two factors cyc and count.
my code:
entity eeprom1 is
port( clk:in std_logic;
sclut std_logic:='1';
ledut std_logic_vector(2 downto 0):="000";
sda:inout std_logic:='1');
end eeprom1;
architecture Behavioral of eeprom is
type arr is array (0 to 2) of std_logic_vector(7 downto 0);
constant data:arr:=(x"15",x"00",x"f8");
signal ack:std_logic:='1';
signal cyc:std_logic_vector(4 downto 0):="00000";
signal count:std_logic_vector(6 downto 0):="0000000";
begin
process(clk) --------1st process------
begin
if (clk'event and clk='1') then
count <= count + 1;
if count <= 63 then
scl<='0';
elsif (count >63 and count < 125) then
scl <='1';
elsif(count=125)then
cyc<= cyc+1;
count<="0000000";
end if;
end if;
end process;
process(count) ---------2nd process-----------
variable bi:integer:=0;
begin
if (cyc=0 and count <70) then
sda<='1';
led<="001";
elsif (cyc=0 and count >=70) then --start high to low---
sda<='0';
led<="010";
elsif (cyc>=1 and cyc<=9 ) then
sda<=data(0)(bi);
led<="011";
if(bi < 7) then
bi:=bi+1;
end if;
elsif(cyc=10 ) then
ack<=sda;
led<="100";
elsif(cyc=11 ) then
bi:=0;
sda<='0';
led<="101";
elsif (cyc>=12 and cyc<=19 ) then
sda<=data(1)(bi);
led<="110";
if(bi < 7) then
bi:=bi+1;
end if;
elsif(cyc=20 ) then
ack<=sda;
bi:=0;
led<="111";
elsif (cyc>=21 and cyc<=28 ) then
sda<=data(2)(bi);
led<="000";
if(bi < 7) then
bi:=bi+1;
end if;
elsif(cyc=29 ) then
ack<=sda;
led<="001";
elsif(cyc=30 and count >70) then
sda<='1';
led<="010";
end if;
end process;
end Behavioral;
expected result :
sda = 1 until cyc =0 and count <70
sda = 0 at cyc =0 and count>70
sda =(sequence of data from constant array) at cyc >= 1 and <=9 .
but the result not consider count value.
so also declared 2nd process as process(cyc,count)
now sda =(sequence of data from constant array) at cyc >= 1 and <=9 .
sda not depend on cyc.it depends on clk input.
so please clerify me.
it will great help.
advance thanx.
Author: Na sowas (Guest)
> begin
This process also depends on cyc and therefore the sensitivity list is
incomplete.
This is a little bit more correct, but look at this:
 process(count)
 begin
    if(bi < 7) then
       bi:=bi+1;   ------- OUCH
Although you (perhaps) will get a fine simulation, this will form a
combinatorial loop in a synthesized design. Because due to the use of a
variable the result of bi depends of the former value of bi. And so bi
should be placed in the sensitivitiy list also. But this is not possible
with variables... :-o
You can use counters like bi:=bi+1 only in clocked processes!!!
This usually is good and its called a synchronous desgin.
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
