Forum: ARM programming with GCC/GNU tools MP3 decoder with cortex M3
von Toto T. (Company: Poulet) (marsther)
I have implemented an MP3 decoder based on helix decoder on a LM3S9B96
microcontroller and I want to play the PCM sample (WAV) decoding through
the audio codec.This board has one cortex M3 core.For play the song in
the board I use the codec TLV320AIC23 of the board .I transfer the
sample to the codec via i2s link by using one DMA controller.But I have
one limitation with the DMA transfer , the maximum transfer I can make
is 1024 items to tranfered , but the size of the PCM output array (MP3
decoder output) is 2304  so he has 2304 short elements (that means
1152*2 =2304).I must to transfer steaming MP3, and I want to used ping
pong mode for this, but I can't used ping pong mode buffer to transfer
1152 items, so I have implement one solution that transfer 576 items in
primary buffer and 576 items in alternate buffer of the DMA controller.I
use 4 buffeurs instead 2 (for transfer 4*576 items=2304).I have 2
primary buffeur and  2 alternate buffer.When the first primary transfer
has done I do the first alternate transfer and so on, beacause I can't
fill primary buffer when he is done he has only 1152 size and my PCM
output has 2304.I refill primary and alternate buffer of the DMA
controller with MP3 decoder , so I refill primary and alternate at the
same time when the second primary buffer is done.
But during the sound play I have some noise in the song and the song is
too slow than original, it's like I lose some sample in the process.
Is anyone have one idea for help Me??I hope you've understand my
context.
Thank you in advance, and I hope someone will help me,
