hello ı need lpc2378(olimex lpc-p2378 dev.board) timer blink sample for
eclipse.
ı tried this code but not worked..
void Initialize(void);
void feed(void);
void IRQ_Routine (void) _attribute_ ((interrupt("IRQ")));
void FIQ_Routine (void) _attribute_ ((interrupt("FIQ")));
void SWI_Routine (void) _attribute_ ((interrupt("SWI")));
void UNDEF_Routine (void) _attribute_ ((interrupt("UNDEF")));
void T0isr (void) ;
Header files
#include "LPC23xx.h"
#include "type.h"
#include "irq.h"
#include "target.h"
#include "fio.h"
int r;
void main (void) {
IODIR0 = 0x00200000; // P0.21 Output
VPBDIV = 0x00000002;
PINSEL0 |= 0x00000000;
T0PR = 0x0000001E;
T0TCR = 0x00000002;
T0MCR = 0x00000003;
T0MR0 = 0x00001600;
T0TCR = 0x00000001;
VICVectAddr4 = (unsigned)T0isr;
VICVectCntl4 = 0x00000024; //4 No int enable (Timer0)
VICIntEnable |= 0x00000010; //Timer 0 int enable
while(1);
Timer 0 interrupt
void T0isr (void) {
r=(r+1)&1;
if (r==1)
IOSET0 = 0x00200000; /* Turn off LED */
else
IOCLR0 = 0x00200000; /* Turn on LED */
T0IR |= 0x00000001;
VICVectAddr = 0x00000000; //Dummy write to signal end of
interrupt
/* Stubs for various interrupts (may be replaced later) */
void IRQ_Routine (void) {
while (1) ;
void FIQ_Routine (void) {
while (1) ;
void SWI_Routine (void) {
while (1) ;
void UNDEF_Routine (void) {
while (1) ;
where is my fault?
regards
Pack the - Complete source-code including startup-code - Linker-script - Makefile (or at least output of the build-process where all options can be seen) into one zip-archive and attach it to a message. You may find this example-application useful: http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
Attached files:here is my bad sample project... please give me any ideas. thax four your reply. =) Regards.
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm... this link's project occured so much errors on the new project :(
HELLLLLLLLLLLLLLLLLLLLLLPPPPPPPPPPPPPPPPPP...ANY IDEAS?? TSSSSSSSSSSSSSSS :(
Attached files:If you have still problems, I have modified the project. It seems that you have copied several files from different projects. Please note that in this project the main clock is 72Mhz. I have lowered the blink frequency so that the LED blinking is visible. PS: I am using the Codesourcery toolchain (arm-none-eabi) so you may have to change the Makefile accordingly. The WinARM toolchain (arm-elf) should work as well.
thanks for ur support didnt work on my workspace.it gave error aagain :s ////////////////////////////////////////////////////////////////////// **** Build of configuration Default for project blinkyy **** make all -------- begin (mode: ROM_RUN) -------- arm-elf-gcc (GCC) 4.4.2 Copyright (C) 2009 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. make: *** No rule to make target `Common/src/Startup.S', needed by `Common/src/Startup.o'. Stop. ////////////////////////////////////////////////////////////////////// ı didnt change toolchain in the properties menu..problem occured " java.lang.nullpointerexeotion what do u think about this error? regards
The file `Common/src/Startup.S' seems to be missing. Did you extract the entire archive? I'd recommend you to start without eclipse as the project files are not very portable. Extract the archive to some temporary folder, adjust the toolchain in Makefile and try to call 'make' from within a dos box in that folder. Just tried that myself (extracted blinkyy.zip, with unaltered Makefile). I am using make.exe from the WinAVR project.
C:\Users\let\Documents\workspace\blinkyy>make -------- begin (mode: ROM_RUN) -------- arm-none-eabi-gcc (Sourcery G++ Lite 2010q1-188) 4.4.1 Copyright (C) 2009 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. Assembling (ARM-only): Common/src/Startup.S arm-none-eabi-gcc -c -mcpu=arm7tdmi-s -I. -x assembler-with-cpp -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -Wa,-adhlns=Common/src/Startup.lst,-gdwarf-2 Common/src/Startup.S -o Common/src/Startup.o Assembling (ARM-only): Common/src/swi_handler.S arm-none-eabi-gcc -c -mcpu=arm7tdmi-s -I. -x assembler-with-cpp -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -Wa,-adhlns=Common/src/swi_handler.lst,-gdwarf-2 Common/src/swi_handler.S -o Common/src/swi_handler.o Compiling C: main.c arm-none-eabi-gcc -c -mcpu=arm7tdmi-s -I. -gdwarf-2 -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -O0 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -ffunction-sections -fdata-sections -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=main.lst -ICommon/inc -Wcast-qual -MD -MP -MF .dep/main.o.d -Wnested-externs -std=gnu99 -Wmissing-prototypes -Wstrict-prototypes -Wmissing-declarations main.c -o main.o Compiling C: Common/src/target.c arm-none-eabi-gcc -c -mcpu=arm7tdmi-s -I. -gdwarf-2 -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -O0 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -ffunction-sections -fdata-sections -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=Common/src/target.lst -ICommon/inc -Wcast-qual -MD -MP -MF .dep/target.o.d -Wnested-externs -std=gnu99 -Wmissing-prototypes -Wstrict-prototypes -Wmissing-declarations Common/src/target.c -o Common/src/target.o Compiling C: Common/src/irq.c arm-none-eabi-gcc -c -mcpu=arm7tdmi-s -I. -gdwarf-2 -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -O0 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -ffunction-sections -fdata-sections -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=Common/src/irq.lst -ICommon/inc -Wcast-qual -MD -MP -MF .dep/irq.o.d -Wnested-externs -std=gnu99 -Wmissing-prototypes -Wstrict-prototypes -Wmissing-declarations Common/src/irq.c -o Common/src/irq.o Linking: main.elf arm-none-eabi-gcc -mcpu=arm7tdmi-s -I. -gdwarf-2 -DROM_RUN -D__WinARM__ -D__WINARMSUBMDL_LPC2378__ -O0 -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -ffunction-sections -fdata-sections -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=Common/src/Startup.lst -ICommon/inc -Wcast-qual -MD -MP -MF .dep/main.elf.d Common/src/Startup.o Common/src/swi_handler.o main.o Common/src/target.o Common/src/irq.o --output main.elf -nostartfiles -Wl,-Map=main.map,--cref,--gc-sections -lc -lm -lc -lgcc -TCommon//LPC2378-ROM.ld Creating load file for Flash: main.hex arm-none-eabi-objcopy -O ihex main.elf main.hex Creating load file for Flash: main.bin arm-none-eabi-objcopy -O binary main.elf main.bin Creating Extended Listing: main.lss arm-none-eabi-objdump -h -S -C main.elf > main.lss Creating Symbol Table: main.sym arm-none-eabi-nm -n main.elf > main.sym Size after: main.elf : section size addr .text 2344 0 .bss 4 1073741824 .stack 1024 1073742080 .ARM.attributes 48 0 .comment 129 0 .debug_aranges 200 0 .debug_pubnames 160 0 .debug_info 716 0 .debug_abbrev 369 0 .debug_line 625 0 .debug_frame 280 0 .debug_str 261 0 .debug_loc 344 0 .debug_ranges 112 0 Total 6616 Errors: none -------- end -------- |
thank you so much ;) working so good ... my problem is .. didnt open archive correctly .. ı followed your advice.. otherwise FIO1DIR,FIO1SET must be FIO0DIR and FIO0SET ;) THANKS FOR YOUR SUPPORT REGARDS ISMAIL
Finally some working interrupt example for this LPC....thanks everyone. Kerbo
very good, it's very useful to me, thank you very much! [Mod: unrelated link removed]
