Forum: ARM programming with GCC/GNU tools Yagarto arm-none-eabi- undefined reference _sbrk
Author: Staffan Bruce (staffan)
Hello,
I'm trying to compile code for the NXP lpc2138 using Yagarto 2.20.1 (gcc
4.5.0?)
After some initial problems with linking (wrong order of libraries) I'm
now down to a single error:
..linking
arm-none-eabi-ld -v -LC:\program1\yagarto\lib\gcc\arm-none-eabi\4.5.0
-LC:\Program1\yagarto\arm-none-eabi\lib -Map main.map -T2138_demo.cmd
-o main.out  crt.o main.o adcHAL.o adf4108.o adf4156.o adcLTC1606.o
adcLTC1864.o armVIC.o commandLineInterpreter.o counter.o fft.o flash.o
frequencyCounter.o irq.o lmx2487.o measurementEngine.o rs232.o spi.o
synthHAL.o system.o systemparams.o timer.o UARTStdIO.o -lm -lgcc -lc
GNU ld (GNU Binutils) 2.20.1.20100303
C:\Program1\yagarto\arm-none-eabi\lib\libc.a(lib_a-sbrkr.o): In function
`_sbrk_r':
C:\msys\1.0\home\yagarto\newlib-build\arm-none-eabi\newlib\libc\reent/../../../../../newlib-1.18.0/newlib/libc/reent/sbrkr.c:60:
undefined reference to `_sbrk'
make: *** [main.out] Error 1
It seems like _sbrk isn't found.
I've been searching a bit and it seems like this may be related to the
arm-none-eabi libraries and it appears as if one solution is to add a
stub for the _sbrk.
I am a newbie at these things so unless I get a library that I can
include or very hands on instructions on how to get past this, I'm lost.
If anyone can help, it would be very much appreciated!
Many thanks in advace!
/Staffan
Author: 900ss D. (900ss)
_sbrk is part of a module which contains the low level functions to
access your hardware. As in embedded systems the hardware from system to
system is different, the newlib (clib for ARMs) don't know how to access
your hardware. Therefore a small module called syscalls.c is necessary.
You can found some examples on this site:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/
Furthermore read the doc for the newlib on the Red Hat website.
900ss
> ..linking
The "inital problems" could have been avoided. If the compiler-frontend
(arm-none-eabi-gcc) is used for linking there is not need for -L
parameters for the toolchain's library-pathes. The linker (*-ld) is
called internally. Some options which should be passed to the linker
need to be prefixed with -Wl, (for example -Wl,-Map=...) when calling
the linker indirectly.
>> ..linking
Martin,
Thanks for the info! Could you please point out an example file
(preferably with a few comments!) that I could have a look at?
I guess I still need the linker program, but that gcc can invoke it
automagically with the right parameters (except for the ones I should
pass myself)?
Regards,
  Staffan
> 900ss
Hello,
Many thanks, I followed the link and found some entries. There was one
package containing syscalls.c, but that was for cortex-M3. Could that be
used also for lpc-213X? Or am I perhaps missing the best entry?
Regards,
  Staffan
webmaster@embdev.netContactAdvertising on EmbDev.net
