Attached files:I'm working on a simple GPS implementation using a ublox neo 5q and a freescale mcf51jm128. The issue I'm having is that I only receive intelligible NMEA data every now and again. I have to reset the uC firmware a couple times before I get an NMEA bitstream. This bitstream may be seen in the first file I have attached "NMEA Bitstream.jpg". instead of this I get periodic unintelligible garbage which takes 3 forms of which one is a combination of X's and H's and may be seen in the second file I have attached "garbage" If anyone can offer me an explanation as to why this should be the case it would be greatly appreciated. Thanks in Advance
