Forum: ARM programming with GCC/GNU tools sprintf %f float problem-YAGARTO
Author: Kamil Bahadir (kamil51)
Hello,
I am using yagarto 4.4.2 version. if i use sprintf with %f the program
seems to be halts!! but no any problem in &d %x....
anybody have the same problem???
Regards
kamil
Author: Alexander (Guest)
Hello Kamil,
i have also problems using %f with this version of the toolchain. I am
using sprintf to print a float number into a string. What i have found
is that the sprintf with %f prints float numbers that are nearly 200
chars long. So i got a overflow of my char array. Now im using an older
version of gnuarm that works without errors.
What type of CPU are you using? Has it hardware float support? Im using
an AT91RM9200 without float support. I'm using soft float and that works
well, with the exeption of the printf function.
Greetings
Alexander
Author: kamil bahadir (Guest)
Hello Alexander,
I am using LPC 2138. it has no float hardw.
i found a solution by using float2str() function.
but no any solution by using "syscall" functions.
Greetings
kamil
Author: Martin Thomas (Guest)
A few thinks you may try to test:
- if enabled: disable thumb/thumb-interwork during tests. Options can be
enabled later when problem has been located.
- check if the linker uses the correct libc and libm (no -L options
poiting into the toolchain installation-directory, arm-*-gcc used for
linking - not arm-*-ld)
- check the defintion of the heap-start address  (linker-script,
map-file, symbol-table) and the sbrk syscall are correct
- make sure dynamic memory allocation works (use malloc and free for
tests). I suggest to allocate at least 8KB during the tests which should
lead to 3 calls to sbrk (with a newlib that has been configured without
SMALL_MEMORY, AFAIK M. Fischer does not configure with SMALL_MEMORY for
Yagarto)
- check if the math-library is linked (option -lm for linkage, library
name libm-a)
- try with the latest version of Yagarto or with Codesourcery G++ lite
for ARM EABI (both arm-eabi)
Hello Martin,
Very thanks for your suggestions. after testing i will be back to you.
Best Regards
kamil
