Forum: ARM programming with GCC/GNU tools YAGARTO for ARM LPC2148
Author: Mahaboob Basha (sha)
Hi Guys,
I am using LPC2148 Arm7 controller. I am very new to the open source
tool Yagarto. I installed jre, yagarto tool, yagarto arm tool chain. i
follow the steps of the blue screen manual and install all the tools but
still i didnt get the result as mentioned in the manual. i get error
when i check the following command in the command prompt. “arm-elf-gcc
--version”. i have attach the manual please go through it. tell me
whether there is any correction to be made. or else please gave me any
other manual or tool(open source) to install(web link). Please help me.
Regards,
sha.
Mahaboob Basha wrote:
> i get error
Check the PATH environment variable. The PATH where arm-elf-gcc.exe is
located should be listed. If not add it manually (see Windows
online-help).
Author: Michael Fischer (mifi)
Hello,
which version of YAGARTO is used?
If you use the new one, 20100501, you must use:
arm-none-eabi-gcc --version
instead of:
arm-elf-gcc --version
The older , non eabi, version of YAGARTO can be found here:
http://sourceforge.net/projects/yagarto/files/YAGA...
Best regards,
Michael
Thanks Michael,
I got the result as mentioned in the Manual. I didnt install the eclipse
ganymede. Because i download it, as a installed package. i just paste
that package in the C: and yagarto tool, yagarto arm chain tool are also
in the C:. I proceed with the manual and upto Workspace section i am
clear. I import keil project, I build the project is in manual. But it
didnt generate the hex file. I enclose the screenshot of the eclipse
window.
Initially the LPC214x.h header file is not available. i enclose the
header file into the directory.
I am not clear why we are importing the keil project? as mentioned in
the manual.
Micheal I need some other manual to follow. I don't know why is making a
mistake Please help me.
Regards,
Sha.
