Forum: ARM programming with GCC/GNU tools iostream - related linker error (GNU/Linux Compiler g++)
Author: Asim (Guest)
I am getting following linker errors using g++
***`__static_initialization_and_destruction_0'
***iostream:76: undefined reference to `std::ios_base::Init::Init()'
***iostream:76: undefined reference to `std::ios_base::Init::~Init()'
GNU/Linux using g++
.\Objects\main.o: In function
`__static_initialization_and_destruction_0':
/cygdrive/c/Hitex/GnuToolPackageArm/bin/../lib/gcc/arm-hitex-elf/4.1.1/.
./../../../include/c++/4.1.1/iostream:76:  undefined reference to
It is a very simple C++ code which is not using any special C++
features.
The code compiles,links and runs fine when <iostream> is "NOT" included
in the main.cpp file.
but as soon as <iostream> is included in the main.cpp file, the code
compiles, but the above linker error is generated.
Any help is appreciated!!!
Thanks!
Author: Rolf Magnus (Guest)
> GNU/Linux using g++
Sure about that? Your paths look like this is Windows/Cygwin.
What's you compiler/linker command line?
Author: Asim Shaikh (asim)
arm-hitex-elf-g++ -mcpu=arm7tdmi -c -gdwarf-2 -xc -MD -Wall -O0
-mthumb-interwork -mapcs-frame  -fsigned-char  -mlittle-endian  -marm
 -I.\Source\  -I.\ -o .\Objects\interrupt.o
.\Source\System\interrupt.cpp
arm-hitex-elf-as -mcpu=arm7tdmi  -gdwarf2  -mthumb-interwork
-I.\Source\  -I.\ -o .\Objects\startup.o .\Source\System\startup.s
arm-hitex-elf-g++ -mcpu=arm7tdmi  -c -gdwarf-2 -xc++  -Wall -O0
 -I.\Source\  -I.\ -o .\Objects\main.o .\main.cpp
arm-hitex-elf-ld  -T.\Settings\main.ld.tmp --cref -t -static
-nostartfiles -Map=.\DOC\DemoC++.map  -stats -lhcclib -lc -lgcc -lm
-o .\Objects\DemoC++.elf
arm-hitex-elf-ld: link errors found, deleting executable
`.\Objects\DemoC++.elf'
arm-hitex-elf-ld: mode armelf
.\Objects\interrupt.o (3kb)
.\Objects\startup.o (6kb)
.\Objects\main.o (35kb)
Author: Andreas Ferber (aferber)
You are not linking against the C++ runtime (libstdc++), which would
provide you with your missing symbols.
It is recommended to use g++ itself (arm-hitex-elf-g++ in your case) for
linking. This ensures that all necessary runtime libraries are included
automatically. If you want to provide parameters to the linker itself
(like -nostartfiles or -Map in your case), you can do this using the
"-Wl,..." parameter to g++, for example "-Wl,-nostartfiles".
Andreas
