Forum: ARM programming with GCC/GNU tools printf hangs problem
von Kamil B. (kamil51)
Hello all,
I am using YAGARTO ver. Newlib-1.18.0  GCC-4.4.2
 if i use printf,iprintf.. function in my code the program halts after
"printf".
(if it is deleted no any problem..)
used form in function like that;
printf("something?????..?\n);
the syscalls.c downloaded from the YAGARTO
page(http://www.yagarto.de/download/yagarto/syscalls.c ..)
to check the  "_write_r" routine is works or not, i insert the folloeing
code linebelow;
IOSET0 =0x00003C00;// LEDs are connected to the p0.10,p0.11,p0.12, p0.13
int _write_r (struct _reent *r, int file, char * ptr, int len)
  r = r;
  file = file;
  ptr = ptr;
//lcd_write_nibbles('A');
#if 0
  int index;
  /* For example, output string by UART */
  for(index=0; index<len; index++)
    if (ptr[index] == '\n')
      uart0Putch('\r');
    uart0Putch(ptr[index]);
#endif
  return len;
The LEDs never light on!this mean that this routine doesnt work.
why?
regards
kamil
von na sowas (Guest)
I can not find any printf in the code...  :-/
Perhaps you could post your code.
And: what happens when you use puts()?
BTW: whats your target processor?
Hello,
Target processor LPC2138. I dont want to use "puts" because i will use
float values in my code. a part of code like this;
if (msg_tip =='A') {   //
       i=0;
       for (i=0;i<16;i++) ascii7bit[i]=((Read_eeprom(i+20)));
       i=0;
else if(msg_tip =='B') {  //store data
       DATA_OUT=2;  //write to RAM
       printf("V=%0.3f Volt",(temperature )*0.00488281);
i need to operate analog values in code.
Regards
kamil
